Thread: Should connected SPA CL be higher than Pool and if so how?
    Mar 2017
    San Diego, CA
    9
    Experts - ~14,500 GAL In-ground pool with connected SPA. SPA will most likely get more use than pool. Also thinking that since temperature will be higher in that water mass the germs will grow quicker. So should the SPA have a higher CL level than the pool? If so how would one accomplish that given both are connected. Normal operation on circulation of the pool has about 10% of the water going back to the SPA which overflows back into the pool (SPA can be isolated when in use for filtering and heating). I'm thinking that because of that it may be best to keep the overall CL level higher than average to account for the SPA than attempt to come up with a strategy to keep them at different levels...Thoughts?
    Best
    GJB
    In ground plaster pool (14,500 GAL) with above ground Spa (500 GAL); Pentair DE filter; Pentair WhisperFlo 3/4 HP pump (pool) and Pentair WhisperFlo 2 HP (Spa Jets); Pentair MiniMax NT Heater
    30,946
    Re: Should connected SPA CL be higher than Pool and if so how?
    Leave them the same. You get enough exchange between the two bodies that trying to balance them out will be far more headache with minimal, if any, benefit.
    Mar 2017
    San Diego, CA
    9
    Thanks Duraleigh - Should I raise overall CL level to account for the SPA germs? I mean instead of say 3ppm I shoot for 5ppm or does it not matter?
    30,946
    What is your current CYA test result?
