Results 1 to 12 of 12
Thread: Running a Kreepy Krawler with a solar cover
    Aug 2016
    Riverside, CA
    378
    I've been considering getting a solar cover for our pool. It is perfect for it too being a rectangle with no curved sections. My question is, how well does the cleaner work with the cover on? The hoses to my suction side Kreepy Krawler get hung up if we leave floating rafts in the pool so I'm concerned they will not allow the cleaner to move. Of course if the pool is covered maybe you don't need to run the cleaner.. HMM..
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Running a Kreepy Krawler with a solar cover
    The robot works fine under the cover. But, true that it is needed much less.
    Feb 2015
    Chandler AZ
    1,061
    A Kreepy Krauly is a suction side cleaner, not a robot. The Kreepy Krauly hose might get hung up a bit on the solar cover.
    A robot has a small diameter low voltage power cord from the in water unit to a properly grounded, bonded and GFCI protected 110v outlet near the pool. The robots plug plugs into 110v, the 110v power is converted to low voltage and sent to the cleaner via the power cord.
    In either case, you shouldn't need to run either cleaner as much because the cover will keep out a good amount of the debris - well, except if the Santa Ana winds kick up by you.
    If needing to use the Kreepy Krauly, you can always pull the solar cover off during the day while the cleaner is in use - this will help minimize heat loss. Be sure to put some type of cover over the solar cover if it isn't on the pool so the sun doesn't beat on it when off the water. Most solar covers I've had come with a thin plastic tarp like cover.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    948
    Before I invested in a robot I used my suction cleaner in the pool all the time under the cover- no problems with it getting stuck/hooked on anything.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Aug 2016
    Riverside, CA
    378
    Quote Originally Posted by proavia View Post
    WOW! That is very familiar.. Looks like my hometown or maybe Redlands. For whatever reason, the area I'm in doesn't get as strong of winds as most of this area but we get those clear days.
    If I were to get a solar cover, I'd not want to have to remove it except when we were going to use the pool. The Spa Cascades into the pool over tile "steps" so that might be of concern too in keeping the cover in place so maybe this idea won't work so well.
    That said, we heated the pool to 84 the last two weekends and today it is 63. The last few days have been rainy and cold but the sun's out bright again today and after a brief cooldown this weekend we're heading back up to 80's and 90's next week. We lost all that heat and the $$$ associated with bringing it on too. A solar cover may have helped somewhat but how much, I do not know.
    triptyx's Avatar
    Apr 2016
    1,476
    My Kreepy runs quite well under the cover - no problems other than the hose occasionally causing water from the spa spillway to run over top of the cover. I fixed that by putting a pool noodle under the cover next to the spillway cutout and it's golden.
    I found that I got a goodly amount of debris in the water even with the cover on - there is enough of a little gap around the edges that leaves can get in, so I usually let the Kreepy run even with the cover on.@
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Feb 2015
    Chandler AZ
    1,061
    Quote Originally Posted by Sammy2 View Post
    I grew up in Fontana in the 60's and early 70's. We usually got the winds first there. I still remember walking northbound to junior high in those 50-60 mph winds.
    Trip's suggestion of a cut out and pool noodle in the area near the spa spillover sounds like it would work well. And, if the spillway isn't on full blast, any water that does make its way on to the solar cofer should drain off fairly quickly.
    You may wish to post a pic of the pool and of the spillway area. Someone else may have additional suggestions on solar cover fitment.
    While you may gain a few degrees during the day, the biggest benefit is the heat retension at night.
    Gene
    Aug 2016
    Riverside, CA
    378
    @proavia I don't know when you're last time here was but since the steel mill moved out you can see Fontana from Riverside where I live in the summertime now. Back then? Stage 3 Smog Alert!
    I'll post pics when I can. Guess I need to cough up a donation to TFP to do that.
    DFW, TX
    24,974
    Hey, that's a great idea!
    More here, CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Feb 2015
    Chandler AZ
    1,061
    The smog really didn't have that much to do with Kaiser. Oh sure, they certainly contributed to it. But their demise isn't the reason for the air quality improvement. Even when the steel workers were on strike in 1972, the smog stayed on - except when the winds blew. My dad worked there and I remember after the strike, all plant workers were given a book of pictures taken looking north, south, east and west. Amazing to see the pollution still was there with most of the plant idle.
    Strikes, smog, and steel A History of Total Health | Kaiser Permanente History Blog
    Hmm, wish I knew where his copy of the book went.
    I drive thru at least once or twice a year. Big difference in pollution, population - and warehouses... And no more Mazzulli's pizza either.
    Yup, great idea making a donation here. And it's tax deductible too.
    Gene
    Aug 2016
    Riverside, CA
    378
    Donation DONE! I've saved at least $30 here and should contribute!
    DFW, TX
    24,974
    Hey! Thanks for supporting TFP!
