Thread: Pool Equipment Cover
    Feb 2016
    McKinney. TX
    42
    Pool has been operating in the blazing Dallas sun for 3 years now. The equipment is located on the north side of the house, gets full sun (and temp) until about noon and then remains in shade the rest of the day. I've noticed the plastic on gauges is "yellowed" due to UVs and the paint on the filter and pump has begun to "chalk." I assume, as this is outdoor pool equipment, that this is normal, but am wondering if folks have built boxes, fences and the like to protect the equipment from the direct sun.
    Anyone have any advice? Thanks.
    12,000 gallon, in-ground, Lunar Quartz-Bermuda finish. Pentair Intelliflo Pump and Pentair cartridge filer. Polaris 280 pool sweep. Circupool SJ40 SWG.
    mas985's Avatar
    Pleasanton, CA
    11,987
    Re: Pool Equipment Cover
    I use a shade sail to keep rain and sun off the equipment. Of course you need something to attach it.
    Mark
    Jan 2012
    'burbs of Augusta, Georgia
    8,583
    Saw the shade sails on sale at Costco this week for $29, and its a great idea! I think I shall add that to Skippy's HoneyDo List.
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Iceman 21's Avatar
    Jan 2017
    Sacramento, Ca
    92
    I have the same issue. I'm thinking of making a frame out of PVC pipes and attach solar window screen fabric to it.
    19,xxx gal gunite pool ,Fafco Solar, Pentair; Intelliflo VS Pump, EasyTouch Control System, Clean & Clear Plus Filter,ScreenLogic2, IntelliChlor Salt Chlorine Generator, 3 IntelliBrite 5g LED lights and 1 Color Cascade LED Light Bubbler. 3 deck jets and 1 sheer decent waterfall
    Jan 2014
    Brookhaven, MS
    45
    I built this last year, mostly for aesthetic reasons and to keep the pipes out of the sun.
    I have since put a hinged top on it. The back side remains open for easy access.screenshot1.jpgscreenshot2.jpg
    18x36 25k Gal Inground Vinyl Pool
    300lb Sand Filter / 1.5hp Single Speed Pump / Intellichlor IC40 SWG / Polaris 280 w/booster pump
    BeachSunH20's Avatar
    Feb 2017
    Las Vegas NV
    143
    Do you have a pic of the top you added?
    Built 9/2016 -10k pool, IG Concrete pool/spa - travertine coping/deck - All Pentair Equipment - Pentair Clean & Clear Plus Cartridge filter-Master Heater 400,000- Pump Intelliflo vst - color plaster - rebel cleaner- Auto -tablet-Chlorinator -Screen logic connect- variable pump - Test Kit Taylor 100.
