Results 1 to 12 of 12
Thread: Measuring chemicals...
    Question Measuring chemicals...
    I'm going to be buying chemicals online and in bulk, so I'll need to find ways to measure them out when putting them in the pool. Been using this for a while for things like muriatic acid, liquid chlorine, and anything else for volume and it's worked well. For weight, I have no idea what to use. So I'd like to know a couple of things.
    • What are you using for volume?
    • Is what I'm using for volume ok for the chemicals we deal with?
    • What are you using for weight?
    • What would you recommend that will be fairly precise for low weight (0-20 lbs)?
    Thanks!
    Rich - 21k gal IG pool/spa, pebble, completed Sept 2016, no water restrictions
    - Hayward: EcoStar pump, SwimClear C5030 cartridge filter, T-CELL-9 sanitizer, H400FDN heater, ProLogic controller
    - Acc: Polaris Vac-Sweep 280 Black Max F5B cleaner, Hayward 6060 booster pump, Taylor K-2006/K-1766
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Measuring chemicals...
    Yes, that is fine for volume. For weight use a cheap kitchen scale, 20 bucks or less.
    Jan 2012
    'burbs of Augusta, Georgia
    8,592
    RIch, I'm curious which chemicals you need so much of that you're going to buy in bulk?
    The biggest thing I ever use (and not that often at that) is buying the 7# Arm and Hammer baking soda from Costco's baking goods aisle. And its lasted two years or more.
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    domct203's Avatar
    Jun 2015
    CT
    3,913
    Quote Originally Posted by YippeeSkippy View Post
    RIch, I'm curious which chemicals you need so much of that you're going to buy in bulk? ..........
    +1
    I use a plastic measuring cup for bleach & a jewelers/craft scale for CYA. I have another plastic measuring cup for MA, but I haven't had to use it yet
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,496
    PoolMath shows chem additions in both weight and volume for powders, which might be useful in a pinch.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Quote Originally Posted by domct203 View Post
    Quote Originally Posted by pooldv View Post
    Ok, cool. Yeah, I was thinking some cheap kitchen scale would be fine, but just wanted to hear it from you guys first.
    The combination of unusually large, constant storms and drainage issues have forced me to slam more than I should be and required rebalancing afterwards. It's really not that much chemicals I'm going to buy. It's just more than what I'd normally get from local stores and at a much better price.
    I would say that for the most part that scales aren't necessary. Chemical additions aren't that critical to get exact. Estimating should be close enough.
    If you have a 50 lb bag and want to add 10 lbs, it should be close enough to just use about 1/5 of the bag.
    Support the site
    JoyfulNoise's Avatar
    May 2015
    14,094
    The only chemical I use the kitchen scale for is cyanuric acid (the wife gets annoyed with me measuring chemicals but, oh well...). I will put a sock in a larger container and then fill it up with two pounds of CYA. I usually have to add between 2 and 4 lbs per year so I like to be a little bit exact with it. Other than that, everything else solid-wise is estiamted (boric acid and DE).
    Matt
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    948
    The only chemical I use the kitchen scale for is cyanuric acid (the wife gets annoyed with me measuring chemicals but, oh well...)..
    That sounds familiar Matt!!
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Quote Originally Posted by JamesW View Post
    I hear you guys. I really do and I'm positive you're correct in that it's good enough. It's just not my personality to roll like that and, so, measuring tools will be used.
    domct203's Avatar
    Jun 2015
    CT
    3,913
    I could see this being true for much larger pools.
    In my 6700 gallon pool it only takes 9oz to add 10ppm to CYA (& 7oz of 12.5% to add 1ppm to FC). I bought a cheap digital scale off eBay for about $8, the 2lb max works fine for my pool. I think I only used the scale twice last season, I use the measuring cup every day for FC.
    Besides, there's something about measuring out accurate chemical additions that appeals to the nerd in me, just like the Speed Stir does!
    Dom - TFP Guide
    I'm with ya, there.
