Results 1 to 10 of 10
Thread: Filter pressure gauge install question
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    I just replaced my filter pressure gauge (back mount gauge on top of filter) and wanted to know if it's normal or ok if the gauge is not perfectly perpendicular to the ground. Mine needed about 1/5th more of a turn to line it up perfectly straight, but it was already hand tight (and a quarter turn), so I didn't want to tighten it anymore and strip something. It seems to be working fine. I've attached a picture of what the gauge looks like installed.
    15k Gallon In Ground Saltwater Gunite Pool and Spa w/ Overflow
    Dolphin S200 Pool Cleaner
    Main Filter Pump - 1.5HP Pentair Whisperflo connected to Triton II Sand Filter
    Spa Pump - 2HP Pentair Whisperflo w/ 2HP Polaris Spa Air Blower
    Resilience PSC3 SWCG
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,299
    Re: Filter pressure gauge install question
    Cajan,
    I can't see where it would matter, as long as you can read it..
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    Quote Originally Posted by Jimrahbe View Post
    Cajan,
    Probably just my OCD kickin lol. I've never replaced one before, that's the only reason I was asking. Just wanted to make sure I installed it correctly.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    The gauge won't care one bit about being out of level. You did the correct thing by not overtightening it.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    May 2011
    lebanon tn
    370
    Looks perfect to me
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    30,954
    What do the "start" and "clean filter" arrows mean? Seems like that's labeled wrong.
    Jul 2014
    Bedford, TX
    9,299
    I believe that it means "It is time to clean the filter".. Not that at that pressure the filter is clean.
    Although I like your idea better...
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    The "Start" is your normal filter pressure when the filter has just been backwashed and all baskets emptied out. The "Clean Filter" is when your pressure has climbed (dirty filter that needs backwashing, baskets with debris that need to be emptied, etc) and it is time to backwash the filter and clean the baskets. It's just a visual guide. You can actually rotate the dial and set it the "Start" arrow on whatever you're clean filter pressure is because people's pools run at different pressures.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    I wouldn't go by those arrows anyhow......that looks like the industry standard of a 10 lb. increase in pressure to me. 25% rise over clean is our gauge.
    30,954
    I understand the labeling now. If they are adjustable, you should reset your "clean filter" arrow to about 14-15 lbs......a 25% increase
