Thread: Yet Another DIY FC project?
    Sep 2016
    Katonah NY
    172
    Hi,
    So I am patiently (not really) waiting for my Stenner pump. It wont get to me before i leave for a vacation. No one can help me with the chlorine because i dont have anyone to watch over it.
    Anyway I was thinking of what I can get that is cheap, fast & easy (thats what she said).
    How about this:
    https://www.amazon.com/gp/product/B001BOD9JI - Aqua Lifter Pump
    https://www.amazon.com/gp/product/B0002563MW - Aquarium hose
    https://www.amazon.com/gp/product/B00025676Y - valve to control flow level
    or (and maybe and)
    McMaster-Carr - a squeeze valve to control flow
    I am a little confused as it may need a check valve due to siphoning.
    Would this work?
    Donldson's Avatar
    NW Ohio
    3,219
    Re: Yet Another DIY FC project?
    I don't know about adding a valve to control the flow, but you are definitely on track for something that have proven to work in the past: My $25 auto chlorinator DIY project
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    Sep 2016
    Katonah NY
    172
    Lol! Reinventing the wheel!
    I was going to add this:
    https://www.amazon.com/Jardin-5-Piec.../dp/B00H4YDY0S
    To the list of parts. I am going to read that thread for some information!
    Any other cheapie DIY threads?
    Rich
    Oct 2016
    Phoenix
    203
    I would not use the flow control valve and would instead maybe use a digital lamp timer to determine pump run time and thus the amount of LC added per day. I keep seeing comments about flow control devices clogging. Eliminating a small orifice in the system will help prevent a clog. Might not be a big deal since you have a better pump system coming soon.
    I just built a similar low-cost dosing system using a $12 peristaltic pump and a used sprinkler timer. I was going to do a write-up as soon as I got a few pics to go along with the description and part list. It's not rocket science. My system is located in a storage shed next to the pool pump so good looks and being weather-proof are not required. Also, with a peristaltic pump (even the cheap eBay versions) you don't have to worry about siphoning.
    Dave in Phoenix, AZ, USA
    12,000 gallon IG (5' max depth) , Pebble-tec,
    Hayward SP2303 Maxflo 1.65 HP, Triton TR60 sand filter, 1 skimmer, Pool Devil skimmer, 3 returns, 1 aerator port, Navigator suction-side sweep, Hayward valve actuator, Rainbird sprinkler timer used for valve automation and chlorine injection. Softened water used for makeup.
    mas985's Avatar
    Pleasanton, CA
    11,986
    Mark
    Sep 2016
    Katonah NY
    172
    I bought a digital timer off amazon for the stenner so I can use it now with the 'diy' vacation pump.
    I am only pumping say 6oz per day into my hot tub so i need it to go slowly. With the aqualift maybe the long hose (20 feet) would slow down the flow vs pinching it.
    On the other hand it makes sense that the Peristaltic pump cant siphon physically.
    I see amazon has this: https://www.amazon.com/Dosing-Pump12...um-Analytical/ and its prime so its pretty easy to send back.
