Results 1 to 19 of 19
Thread: how many gallons??
    EmilyOTR's Avatar
    Feb 2017
    Ferndale, MI
    333
    how many gallons??
    Everyone here always wants to know how many gallons the pool is. How do I find out? I'm buying a house and the owner doesn't know, he suggested I call the pool store they use. I did, and he said he'd guess 12-15,000. is that the closest I'll get?
    Emily
    Another question. Type of Filter? I'm not sure what this means. I know the pool currently uses chlorine tablets but we are switching to a SWG. but this doesn't impact "type" of filter right?
    30,941
    Re: how many gallons??
    Provide the measurements and we can help you.
    22,701
    The 12,000 to 15,000 gallons is close enough for now. Once you get to using and maintaining it, you can use chemical additions to narrow down the size more closely.
    If you can read anything off the equipment or post pictures of it we can most likely tell you what type and in some cases what size the equipment is.
    May 2016
    West Bloomfield, MI
    756
    Emily, that's correct. The method of adding chlorine to the pool (pump, manually, tabs, SWG etc) doesn't impact the type of filter (DE, sand, cartridge) with a few exceptions noted here:
    Pool School - Pool Filter Comparison
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    EmilyOTR's Avatar
    Feb 2017
    Ferndale, MI
    333
    Thanks. Once we get keys I will.
    -Emily
    IG plaster pool, approx 12-15K gallons, Pentair IC40 SWCG, sand filter Pentair Triton II 325 lbs 24" 3.14 ft2, Sta-Rite Max -E-Pro pump, booster pump - Pentair LS-MS05, Polaris 380 vacuum, TF-100 Test Kit and K-1766 Salt test kit
    EmilyOTR's Avatar
    Feb 2017
    Ferndale, MI
    333
    We got keys to the house! Now someone else I spoke with says he thinks it's closer to 20k. Here's what I have.
    -Emily
    22,701
    You'll need to pump the water off the cover to be able to tell what the water underneath looks like.
    You have a heater. You'll need to unwrap it before firing it up.
    That's a Sta-Rite Max-E-Pro main pump, but I can't tell what size it is. Looks like maybe a 1 hp.
    You also have a booster pump, which means that you have a pressure side cleaner. It's a Pentair LS-MS05.
    That tall canister looking thing is an inline tablet feeder. It says Bioguard on it, but it's a Pentair Rainbow 320 with their label on it.
    Everything looks in pretty good shape. The fact that the heater is covered hopefully means it was winterized correctly and you won't have much trouble opening it.
    Teald024's Avatar
    Aug 2016
    Lyme, NH, formerly Columbus, Ohio
    1,488
    and a sand filter - Pentair Triton II, 325 lbs, 24", 3.14 ft2.
    With the irregular shape pool, we would need some measurements and water depth to estimate the volume of water. And a picture of the pool from up as high as you can from your deck.
    EmilyOTR's Avatar
    Feb 2017
    Ferndale, MI
    333
    The 2 straightish edges are 35' x 20'. The shallow end is 3' and the deep end is 5'
    -Emily
    EmilyOTR's Avatar
    Feb 2017
    Ferndale, MI
    333
    This is as high as I can get.
    -Emily
    Teald024's Avatar
    Aug 2016
    1,488
    Try this link . It may be an easy & close enough approximation until you can refine it further. The chemical addition method can get you closer once you feel comfortable testing and adding chemicals.
    EmilyOTR's Avatar
    Feb 2017
    Ferndale, MI
    333
    That link didn't work.
    -Emily
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,150
    how many gallons??
    The formula is length x width x depth x 7.5. I'd estimate 33x18x4x7.5=18,000. You can dial in your estimate over time by comparing expected chemical changes with actual changes based on a given product addition.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Teald024's Avatar
    Aug 2016
    1,488
    how many gallons??
    Quote Originally Posted by EmilyOTR View Post
    Oops , lol. It was the Pentair website
    Pentair.com>Support>Tools>Calculators>Pool Volume Calculator
    EmilyOTR's Avatar
    Feb 2017
    Ferndale, MI
    333
    Quote Originally Posted by bmoreswim View Post
    Thank you!
    -Emily
    22,701
    I forgot to post the filter. Yeah, it's a Triton II TR60 with a side mount multiport valve.
    I'd also guess that the pool is between 12,000 & 15,000 gallons.
    EmilyOTR's Avatar
    Feb 2017
    Ferndale, MI
    333
    Quote Originally Posted by Bama Rambler View Post
    Oh, why? Did you see what bmoreswim posted? Why do you disagree with that?
    -Emily
    22,701
    I have a program where I can model a pool if I have a few dimensions, and I can usually get pretty close to the volume. Also, the majority of the time, people tend to overestimate volumes. It may wind up actually being a little larger than my estimate, but about 15,000 gallons would be a good place to start in Poolmath.
    EmilyOTR's Avatar
    Feb 2017
    Ferndale, MI
    333
    well my pool is covered too, so it's hard to measure right now.
    -Emily
