Results 1 to 8 of 8
Thread: Pentair Racer - Wheel replacement guide
    Feb 2017
    Sanford, NC
    2
    I'm looking for a guide on how to replace the small wheels (360236) on the Pentair Racer (360228).
    The wheels kept falling off, and the replacement for them came in with a white bearing where the shaft sleeve would have been.
    I've been unable to ascertain the exact method for getting these wheels to attach to the splined shaft. Can anyone help or direct me to where I need to be looking?
    This is the wheel set that was received when ordering the replacement kit.
    This is what is being replaced and keeps falling off.
    Mar 2015
    Sugar Land , TX
    446
    Re: Pentair Racer - Wheel replacement guide
    Looks like you were sent wrong part
    Mar 2015
    Sugar Land , TX
    446
    Pentair Kreepy Krauly Racer Parts at Sunplay (Page 2)
    Maybe the spline is already pressed in. What if you remove your old spline
    The more I look at it though it just doesn't not look correct
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Feb 2017
    Sanford, NC
    2
    It does appear to be the wrong part, but this is the third set that Pentair has sent out. All are exactly the same.
    I can find no instructions on how to go about replacing these wheels with this bearing inserted, and the wheel with the bearing removed does not fit properly and falls off promptly.
    Mar 2015
    Sugar Land , TX
    446
    Can you post a pic of the front side of the new wheel they are sending you
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    See post started by "finethreads" at 2:42 today about the same model.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Jun 2017
    Dallas/Texas
    1
    PTS, did you ever find out how to replace the new small wheels as I have the same problem. Have submitted a request to Pentair, but not heard back yet.
    Aug 2017
    Beaumont/TX
    1
    This is what is being replaced and keeps falling off.[/QUOTE]
    This is exactly what my old wheel looks like today, 8-12-2017. I have not ordered a replacement kit yet.
    Have you ever received a replacement kit that works? If so, please tell me how you did it.
    Thanks.
