Thread: Hawyward 1500 , RS1500 two speed pump replacement
    Mar 2014
    Fort Worth, TX
    24
    Hi All!
    Thank goodness for this sight. It's helped me a lot in the past and I wanted to see if I could get some more advice now that i'm having another pool issue. My pool pump stopped working . I think it's the start run capacitor as it was making a buzz like it was going to work and then just stopped buzzing completely. I haven't taken it off yet to start checking with a multimeter, but I thought maybe now would be the perfect time to replace my pool pump with a more energy efficient one. The current pump is a Hayward 1500 (Model: RS1500) 1.5 hp pump. I've done some reading but i'm not quite sure what the best option would be here:
    1. Test the capacitor and just replace the capacitor (if that's really the problem).
    2. Replace just the motor? Is that possible? From what I read a two speed motor seems to be the most economical choice. Is there any suggestions on something I could buy and fit onto it? Would only a certain type of model fit my pump?
    3. Replace the entire pump?
    Any advice?
    Thanks a lot,
    --Lee
    25,000 Gallon Pool, In Ground, Plaster, DE Filter (need to get model), need to get pump, pool build year unknown
    Mar 2014
    Fort Worth, TX
    24
    Re: Hawyward 1500 , RS1500 two speed pump replacement
    I'll probably go with the dual speed motor replacement: A.O. Smith 1-1/2 HP Round Flange Dual Speed Full Rate Motor (STS1152R) - INYOPools.com
    My impression was dual speed motor replacement was the most long term economical option.
