Thread: Loop-Loc or Merlin cover?
    It's time for a new cover. We have a Merlin mesh cover, it's now about 15 years old, and needs replacing. Too many seams undone and bird holes to repair.
    Loop Loc supposedly has a solid cover with mesh sections so water still drains in and doesn't collect on the cover.
    Merlin supposedly has a smart mesh that doesn't allow any sunlight in.
    Can anyone shed any light (rimshot) on which brand I should go with and why? Do they products do what they claim? Or should I just go standard mesh, etc.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,151
    Re: Loop-Loc or Merlin cover?
    We have a Merlin Smartmesh cover. I am very pleased with it after 4 years. I open each spring (albeit early) to crystal clear water (and close late). What gets in is mostly just the inevitable worms and debris that will sneak below any cover. I feel the components are of a very high quality and would be similar to Loop-Loc. I would have no hesitation choosing the cheaper of a Loop-Loc mesh or a Merlin Smartmesh cover.
    I would not get a solid cover because a) the weight and b) the only benefit is keeping sunlight and debris out (which my mesh cover does great at).
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    How early do you open and how late do you close? I keep a bucket on the stairs, inside of which goes a sump pump which I hose to the other end of the pool, and I put pucks in the bucket when it gets warm in the winter (as it always does). I usually open end of April/early May and close end of September/early October. Pool usually takes 2-3 days to clear up upon opening, sometimes longer. One year it was perfectly clear.
    Do the newer mesh liners prevent more light than older ones?
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,151
    Smartmesh is likely newer than yours was. I open around April 20 and close around October 20. Water temps should be below 60 for both.
    I raise FC to SLAM before closing and then maybe add something if it warms before April but hasn't really been an issue.
    The fellow I'm going to use said if I open as normal (late April/Early May) and close as normal (late September/Early Oct) I should have a clear pool. That would be awesome if he's right. I currently have duramesh.
