Thread: Hard Plumbing Intex Pool
    Mar 2017
    Albany
    1
    HI! My husband and I are wanting to hard plumb our 26x52 Intex pool. Right now, it's basic, still have the intex pump, and hoses. We have a Hayward vari-flo sand filter we are hooking up, and my husband wants to hard plumb and add a fountain while we are doing that. The only question he really has is for the setup/ and fittings that go to the pool itself? If anyone can give me step by step fittins, and/or pictures, that would be so helpful!! Thanks!!!!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    Re: Hard Plumbing Intex Pool
    My suggestion is to ditch the Intex fittings and install a Hayward through the wall skimmer and return eyeball. They'll work much better to keep your pool clean and will mate right up to your Hayward filter.
    You have to cut your liner, but just take a deep breath and do it. Many of us have, and I've not seen a single person yet that ruined their pool.
    You can connect an Intex hose to a 2" PVC fitting by adding an extra rubber washer (the threading is different and it won't tighten up without the extra washer), but this isn't the optimal solution. I had to do it to use my Intex robot.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    There are also these adapters that you can use to hook up 3rd party pumps, etc., to Intex hoses.
    Amazon.com : GAME 4560 40mm to 1 1/2 Inch Conversion Kit (For Intex Garden
    I used them to connect my non-Intex pump and filter.
    Pentair IC40 SWG
