Results 1 to 8 of 8
Thread: Polaris booster pump issue
    Oct 2015
    Pearland, tx
    9
    I have been battling a Polaris booster pump issue for a while and while many posts are close to the issue, this one seems unique.
    My pump will not start on its own. I can energize it but no flow. Once I hand spin the shaft, it comes flying on and works like a champ for hours. I have checked the voltages and it reads fine. I have completely uninstalled it and opened it up to check for internal issues (impeller, etc) and installed all new seals. I have changed the run capacitor out twice with new ones of the exact same rating. I have tested the capacitors as well to make sure they work well. I confirmed through replacement that the supply valve is clear and fully open and my main pump runs well with good pressure. I am at a loss. Can the actual wires to the capacitor be broken and it still run? It appears to be a run capacitor and not a starting capacitor based on its numbers.
    Another observation is that a couple of weeks ago, there was enough flow through the pump that it would very slowly spin the shaft while off. More recently, that is not the case.
    Like I said, all I have to do is give it a slight twist and it takes off.
    Any ideas would be appreciated... would love to get back to it cleaning on a schedule.
    13,000gal SWG in ground gunite pool with elevated spa and water feature.
    2.2 hp whisperflo pumps (x2) and booster pump for Letro legend.
    TR-100 sand filter. TF-100 testing kit.
    Pool owner since 10/2015. (Houston, TX area)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Polaris booster pump issue
    Essential Links:
    Jan 2014
    Brookhaven, MS
    45
    Is the pump wired for 110v or 220v?
    I just got a new booster pump and decided to go with 110v this time instead of 220v.
    18x36 25k Gal Inground Vinyl Pool
    300lb Sand Filter / 1.5hp Single Speed Pump / Intellichlor IC40 SWG / Polaris 280 w/booster pump
    Oct 2015
    Pearland, tx
    9
    220v
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,764
    Does the motor make any noise when you turn it in and it doesn't spin (hums)?
    does this happen every time you turn it on?
    What exactly are you doing when you "give it a slight twist"?
    Factory Warranty Station for:
    Jandy/Zodiac, Pentair, Sta-Rite, Raypak (Rheem, Rudd), Polaris,
    Oct 2015
    Pearland, tx
    9
    No additional noise.... just hums and if I don't spin the shaft, it will trip off on high temperature ( I believe it is a high temp shutoff).
    This is every time I test it. I don't have it in the daily cycle while I have this issue. I put it in manual and run it for a few hours.
    I just grab the exposed shaft at the back of the motor with three fingers and spin it (pull my hand away quickly) and it starts right up.
    30,950
    The most common issue is the start capacitor. I have never done it but there are plenty of youtube videos....pretty cheap, too.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,764
    If you have replaced (with brand new?) and also tested those capacitors, I'm afraid that the motor is done. If it did this only some of the time, i would think dead spot(s) on, or a contaminated armature.
    Some shops, mine included, won't mess with working on motors. However that's not to say you can't bring it to a motor shop yourself for repair or rebuilding.
