Thread: Help with Saltwater slam
    Jul 2015
    Poway, CA
    64
    Hello,
    I need a little help on a slam for Saltwater. I have experience with a chlorine slam but not with a SWG. Much help is appreciated.
    Thank you,
    Current levels:
    TC 4.5
    CC 0
    CH 550
    TA 114
    PH 7.8
    CYA 60
    Salt 3000
    27K Gal, IG Plaster, Hayward EcoStar Variable Pump, Pentair DE FNS Plus Filter 24, Hayward AquaRite with extended life T-CELL-15
    The Pool Cleaner Sweep
    Build in 1969
    Water From City - Tested CH is 500
    TF-100 Test Kit
    Donldson's Avatar
    NW Ohio
    3,219
    Re: Help with Saltwater slam
    Step 1: Turn off SWG
    Step 2: SLAM as normal
    After you complete the SLAM and your FC level returns to normal you can fire up the SWG and continue as normal. Since you are adding chlorine manually anyway no reason to leave it on, might as well save on the wear and tear.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    Jul 2015
    Poway, CA
    64
    Should I use bleach or liquid chlorine? Doesn't liquid chlorine add to the salt level? Also, should I increase my CYA to 70 or 80?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,995
    Quote Originally Posted by Imracerx View Post
    I wouldn't increase CYA until post SLAM as increasing CYA raises initial chlorine demand.
    Bleach is liquid chlorine but just likely a different percentage than the pool store liquid. The additional salt is extremely minimal.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jul 2015
    Poway, CA
    64
    Quote Originally Posted by AimeeH View Post
    Thank you!
    Build in 1969
    TF-100 Test Kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,900
    Bleach and liquid chlorine are the same product, just in different concentrations.
    "Bleach" is the household term for chlorine concentrations from 3 - 8.25%
    "liquid chlorine" is the industrial (& pool industry) term for concentrations above that, most commonly 10 & 12.5%. You will often see it labeled as "liquid shock".
    This is part of the pool industry art of confusion & deception. They say you can't use "bleach" in your pool because of the added salt and "dissolved solids" it add. But, use this liquid shock, it works great.
    Support the site
