Results 1 to 9 of 9
Thread: Pre-Purchase AGP equipment questions
    IrishEyesSmiling's Avatar
    May 2016
    Richmond, VA
    78
    Just want someone to double-check this equipment. Package originally came with Hayward equipment, but per TFP's suggestion, I requested a 2 speed pump and they changed to Pentair. I'm all for saving in the long run so if I pay extra to upgrade now only to enjoy the benefits later count me in!! I plan to attempt the TFPC.
    15x30x54" AGP
    Pentair 19" Sand Dollar 150lb sand filter with a 1.5HP 2SP Dynamo pump
    Hayward AquaTrol (18K gallons)
    15'x30'x52” 12K gallon Wilbar Discovery/Innovation Resin AGP buried 2’ w/ wood deck. Hard plumbed Pentair 1.5HP 2SP Dynamo pump, Pentair SD40 sand filter, Pentair iCHLOR 30 SWG
    500 gallon spa w/ ozonator using Dichlor/chlorine. TF-100, Taylor K-1766, & Speedstir. Dolphin S100 "Flóki". My 2017 Build Thread
    CLICK HERE to Become a TroubleFreePool Supporter! // AmazonSmile: You shop. Amazon gives.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Pre-Purchase AGP equipment questions
    Sounds like you have a great plan going. The only suggestion I have is to get a 30-40k gallon rated salt cell for your size pool. You will have to run the pump less and the cell should last about twice as long.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Jan 2012
    'burbs of Augusta, Georgia
    8,583
    If you buy a Pentair SWG instead of the Hayward, making it 3 Pentair products at once, I believe they will extend the warranty.
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    May 2016
    Richmond, VA
    78
    Excellent - I've asked for the Pentair SWG options. Thanks so much!! Do you think it's necessary to upgrade the Sand Dollar from SD 40 (150lbs) to SD 60 (250lbs)?
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    A bigger sand filter will go longer between backwashes. For your setup you wont notice much else BUT it won't hurt you to go bigger either. If the cost difference isn't much and fits your budget go for it.
    Chuck-
    May 2016
    Richmond, VA
    78
    Anyone have experience with Pentair's SALT CHLORINE GENERATOR MODEL iCHLOR 15, iCHLOR 30?
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    In general the Pentair equipment is good stuff. If you end up going with a SWG get at least the i30. You want to size the salt cell for at least double the gallons in your pool. The cell will last longer and you wont have to run your pump as long to maintain chlorine levels.
    Chuck-
    Jan 2017
    Monterrey, NL, Mexico
    492
    I ran the Ic-15 on the same AGP with no problems for 4 season. The best investment was the sand filter by a longshot!
    Felipe
    7,500 gal Rectangular, Easytouch 8, Air+water temp sensors, Screenlogic2, IC40, intellibright5g color12v, Intelli pH, SD 70 filter w/Zeolit, Magicstream Laminars, waterfall. Raised Monolithic concrete lined with glass beads.
    In Sunny Monterrey,Mx!
    Teald024's Avatar
    Aug 2016
    Lyme, NH, formerly Columbus, Ohio
    1,488
    Quote Originally Posted by Trimble07 View Post
    You either do TFP methods or you don't, there is no attempting! As they say, it's not rocket science...
    Welcome to TFP, I'm sure you're here to stay!
