Thread: Yet another hot tub draining thread...
    Mar 2017
    San Antonio, TX
    1
    Hi all,
    This is a great resource. Glad I found it!
    Anyway, just moved into a new house and noticed that the hot tub drains to pool level every night when the pumps rest. I have seen a lot of threads here and elsewhere with ideas.
    I don't think I have a check valve installed at all. Before I go through the trouble and expense, as I see there are alternate reasons for this symptom, the question is...
    Without a check valve, is it guaranteed that the spa will drain to pool level with the pumps off?
    EDIT: Should mention that I have the drain from spa to filter completely off. Have about 80% pool skimmer 20% pool main drain. Return is 50-50 spa and pool.
    Jonathan
    Apr 2015
    tucson, arizona
    1,312
    Re: Yet another hot tub draining thread...
    Would have to post some pictures of your equipment plumbing for us, so we could determine what might be wrong.
