Thread: New Pool Owner - Pentair Easy Touch Programming
    Mar 2017
    housotn tx
    2
    Hi there. I just moved into a new house and haven't messed with the automation. It's been doing it's thing for about a month now without issues. However, over the weekend it started draining the spa. I can refill it by going into manual mode and turning on the filter pump. As soon as I turn on auto mode it drains. I'm thinking it's programmed to do this but it hasn't done this in a month. Can anyone provide insight as to whether this is something that should occur and whether it can damage anything.
    I captured this video that shows the valve moving.
    Pool - YouTube
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,277
    Re: New Pool Owner - Pentair Easy Touch Programming
    M,
    Welcome to TFP... A Great resource for all your pool questions..
    I don't think this is a program issue, it sounds more like an operation issue.
    I say that because I'm not sure why you are out of the auto mode??? What is it that you are trying to do?
    Basically, the system stays in auto most of the time.
    It is either in Pool Auto or Spa Auto.
    I think the valve is just returning to where it is supposed to be.
    If you can tell me what you are trying to do when you take it out of the auto mode, and what buttons you are using, someone here might be able to help..
    MARCO...polo's Avatar
    Oct 2014
    East Contra Costa County CA
    102
    snipped
    Quote Originally Posted by Jimrahbe View Post
    Is it possible the switch on the actuator was accidentally moved?
    13,000 gal.Peanut shaped IG Plaster (med. gray) w/ 7' raised spa. ALL Pentair: Intelliflow 3hp VS, Cartridge filter, 400,000 btu heater, 2.0hp spa motor, Easy Touch control panel & is4 spa side switch, Intellichlor 40C SWG, Paramount PV3 In Floor cleaning system, spa spillway and two sheer descents. Solar: 10 FAFCO panels 1.5hp booster. Testt kits: K-2006 & K1766 (Chloride/Salt) Fill date August 15, 2114.
    Jul 2014
    Bedford, TX
    9,277
    Quote Originally Posted by MARCO...polo View Post
    snipped
    Maybe, but at this point I do not have enough info to even make a good guess..
    It may be a bad actuator or it may be, as you point out, that someone has gotten the actuators out of sync.
