Results 1 to 9 of 9
Thread: Sealed Air Solar Panels
    Hello Everyone,
    Is anyone aware if Sealed Air still makes solar panels? I've been having a bit of a tough time in South Florida locating them, and I'm thinking maybe they've stopped manufacturing them?
    If anyone has some knowledge on the subject, please share. I have a ruptured panel that needs replacing and I'm investigating replacing the panel vs replacing the entire solar heating system.
    Thanks in advance,
    Mike
    10000 gal. 14 x 28 IG Concrete Florida Gem
    Pentair Intelliflo VS Pump
    Pentair Cartridge Filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Sealed Air Solar Panels
    Welcome to TFP!
    I haven't heard of them before but I was curious and did some looking around. Found these:
    Sealed Air Solar Pool Heating Products
    All Efficient Products AEP Solar Pool Heating Components
    Thanks for the reply. I wrote this right before we went away for a few days with the kids, then forgot about it. Now back to real life.
    I have called the number. When using the extension, the line immediately hangs up. The main switchboard just went to voice mail.
    The other site doesn't service my area, but maybe I can call them and get some info, and maybe buy a panel if possible and have someone install it.
    Thank you,
    Feb 2018
    Walnut Creek/CA
    8
    I also have Sealed Air solar panels for 21 years now. I also have a slight leak, but I think that it is the connection pipe between the panels. When I asked other pool services about them, they said that they are no longer made. What I haven’t done yet, is to actually call Sealed Air to see if they might have some stored in a warehouse somewhere. Please let me know if you find out any info. Thks
    18k Gallon In-ground pool/spa Pebble Tec Plus w/waterfall, Hayward ProLogic Controller-16 plus extension, Hayward EcoStar SP3400VSP, Hayward TriStar, Hayward Booster, Polaris 380 Black Max Pool Sweep, Pentair Clean-N-Clear Plus 420 Filter, Pentair Rainbow 320 Chlorinator Feeder, Paramount Para Level Auto Water Leveler, Pentair Purex Triton MiniMax 400 Heater (21 yrs), (7) 4x12 solar panels (21yrs).
    Jun 2018
    Wesley Chapel, FL
    1
    I have 2 still in box Sealed Air FS-48 Collectors, send me a message if still interested
    Jul 2018
    Danville
    1
    When you say Sealed Air FS-48 Collectors are you talking about the panels themselves?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    ya what about repairing the affected panel?
    I had a Solar Industries panel leaking on one of the tubes and was able to fix it for a few bucks
    and 30 minutes of time.
    Basically cut a clean straight hole in the tube on both sides of the leak, then shove a nylon
    bolt with the head clipped off with some liquid nails injected in the hole first.
    Dolphin E10 Cleaning Robot.
    Aug 2018
    AUBURNDALE
    2
    do you still have panels i have sealed air FP48 12ft non framed will your panels work ?
    Aug 2018
    AUBURNDALE
    2
    Kokko do you still have collectors would you like to sell?
