Thread: Preparing for pump to be off for 48 hours
    Jun 2012
    Austin, TX
    97
    I am having my stone sealed next week and the installer says I will need to keep my pump turned off for 24 hours before and after the sealant is put on to make sure the stone stays dry. Is there anything I should do to prepare my water for this? Should I be worried about my chemicals during this time?
    32x15 freeform gunite pool (approx 15,000 gallons) with a 7x7 raised spa with 2 spillovers - tanning ledge with 2 bubblers - All Hayward Equipment - ARQ15 SWCG - 400btu heater, 60sq ft DE filter - 2HP EcoStar VS pump - Oklahoma flagstone coping - MasterTile MASMIX 3 1x1 - Sundek - Crystal Stones Smooth Caribbean Blue - TF-100 - Doheny's Discovery Robot
    Jun 2014
    17,340
    Re: Preparing for pump to be off for 48 hours
    With the nicer weather we've had lately, perhaps not a bad idea to increase your FC level just to help keep algae away. Perhaps ensure pH isn't about to climb over 7.8. The other levels should be fine for just a couple days.
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    422
    Brush? Slowly & Carefully?
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    I would raise FC up to SLAM level for your CYA just to be on the safe side, FC/CYA Chart.
