Thread: SLAM with CYA at zero???
    Jun 2015
    Houston, Tx
    19
    I had a leak in my pool this winter and I lost basically all the CYA. It is now time to get the pool ready for the summer with a SLAM. I know that the lower my CYA is the less chlorine I have to use for my SLAM. Is there any problems with doing a SLAM with a very low CYA?
    In ground 30,000 gallon rectangular plaster/pebble pool, hot tub with blower, 2 HP Pentair WisperFlo Single Speed Pump, 420 Pentair Clean and Clear Plus Cartridge Filter, Pentair Rainbow 320 Chlorinator, Easy Touch Control System, Pentair 400K BTU heater, Interfab G Force Slide with dedicated 1 HP pump, Travertine Decking, CoverStar automatic pool cover
    domct203's Avatar
    Jun 2015
    CT
    3,900
    Re: SLAM with CYA at zero???
    Without any CYA the chlorine will be very harsh on the pool surfaces, and UV (sun) will eat up the FC quickly. It would be best to get the CYA up to 30ppm if you can.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    30,954
    It's just a little more complicated when it comes to TOTAL chlorine used but Domct203 offers the best advice.....bring it up to around 30 ppm.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Already too warm in Houston to go without CYA!
