Thread: Spa Orifice Removal
    Mar 2017
    BAYTOWN
    2
    Spa Orifice Removal
    Hello everyone 1st post but I think I found the right place to cure my current and future pool\spa issues. So thanks in advance!
    Problem
    I have some jet performance issues and need to remove my orifices\nozzles. I have one of my 4 spa jets pushing harder than the others and can see an object in another. I had a heater t-stat\bypass\check?... fail in my old heater and found some parts in one of my pool returns. I suspect the same with the spa returns. I drained my spa down, removed the eyeballs and found the orifices to be for lack of a better term shaped like a Hershey kiss hollowed out from the point all the way through all of the ones I see while searching are hex shaped. The jet pushing the hardest has the inner part (looks to be a resizing insert) of the orifice missing and I suspect it to be father down the line in the next jet since I can see a white pvc looking liner object in it. The orifices have 2 maybe 1/8" holes on opposite of each other so I am looking for a tool to remove them and a type\manufacture for possible replacements in the event I damage or destroy some is the process of removal.
    Thanks, Tt
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Spa Orifice Removal
    Hey Kona! Welcome to TFP!!
    This has been sitting a while, and sorry we havent said hi. Hopefully youll get some insight on this, but I wanted to welcome you and get this bumped to the top. Enjoy the forums!!
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Welcome to TFP!
    INYO Pools sells various spa jet removal tools and replacement jets.
    Apr 2015
    tucson, arizona
    1,314
    Mar 2017
    BAYTOWN
    2
    Looks like it but mine have a second orifice in the center like an insert and my research on this PN does not bring anything like it up. Is there a different type or brand that looks the same? Maybe this?
    SPX1430B1 Jet Air Spa Insert
    Apr 2015
    tucson, arizona
    1,314
    I believe they came with the original jets and were used to balance out multiple jet flow
