Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Taylor Speedstir Review
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello All,
    So I've taken the plunge and purchased the Taylor Speedstir to utilize my with my test kit. Used it for the first time today here's my impression and review.
    First and foremost, it's a nifty addition to the test kit and it makes me feel geekier than I already am with my test kit!
    The bar stirrer takes up about 1.5 ml of space. I measured the water first then added the bar stirrer, 10ml went to 11.5 (their are markings on the clear tube that comes with the kit).
    Yes the bar stirrer does fit in the test tube that comes with the K-2006, it's tight but does work.
    I did use the stirrer when doing the drop borate test, and water did not come out of the test tube, but it sure made doing that test easier. Actually it makes all the test easier, instead of drops, swirl, drops, swirl, just put in the water, the bar stirrer, turn it on, start adding drops.. Viola!
    It it required, nope, but if you've got an extra $35 bucks that you want to spend, it's a geeky tool, that makes testing a bit easier.
    Oh, remember don't toss out the magnetic stir bar, when you pour out the solutions.
    5/5 stars.. huge geek factor!
    Jan 2012
    'burbs of Augusta, Georgia
    8,592
    Re: Taylor Speedstir Review
    Quote Originally Posted by bobodaclown View Post
    Viola? I took viola lessons as a child. I was traumatized because they ran out of violins before they got to me, and handed me that big ole viola. It was like being handed a tuba instead of a clarinet. LOL
    Oh yeahhhhhh.... done that a time or two and never found 'em in the grass! Now I order extra and keep one for each testing tube.
    Yeah it is
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Sep 2016
    Dallas, Texas
    188
    Started using one two weeks ago...couldn't agree more! Makes testing a breeze!
    Matt- IG gunite pool and spa built Summer 2016: 32' x 20' overall with two 4' x 8' tanning ledges. 6'x6' attached spa with spillover. Depth 3' to 5' to 4'. 16.4K gal. Lueders Limestone retaining wall and coping. Equip: Pentair SVRS vari. speed pump. Pentair 60 sq. ft. DE filter. Pentair Kreepy Crawly Plat. cleaner. Pentair MasterTemp 400,000 BTU NG heater. 1.5 HP spa air blower. Nature2 Sanitizer. Taylor K-206C. My 2016 Build
    Dec 2014
    Riverside California
    494
    My wife thinks I am a mad scientist when she sees me using the Speedstir. Seriously, it does make testing easier and well worth the money.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    domct203's Avatar
    Jun 2015
    CT
    3,912
    Love mine! Not only does it make the testing easier, but more accurate and much more repeatable.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    To keep from losing the stirrer, I pour the different solutions into a small plastic measuring bucket. If you pour carefully, you can keep the "bean" in the vial but if it slips out, you can easily retrieve it.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jedisparky's Avatar
    Mar 2017
    L.A. CA
    101
    Oh... I'm ALL over this....getting my beginner pool geek on!
    Loc: So Cal Full Sunlight, IG 30'x15' Rectangle, 21,000gal w/ 2100gal Jac w/ Spillover
    (SWG) Pentair Intelli IC40, Pentair Intelliflo Variable Speed UEE Pump
    Pentair Mastertemp 400 Pool and Spa Heater
    Pentair Clean and Clear Plus Cartridge Filter CCP-420
    Intellibright 5G Color Pool and Spa Lights, Hayward Nav Pro Pool Vac, Taylor-2006
    JoyfulNoise's Avatar
    May 2015
    14,094
    I actually have two speedstir's so I guess that makes me doubly-geeky However, I do have one complaint - I wish they'd either slow down the spinner or give you a variable-speed selection. I find the SS works a lot better when the batteries are a little used; fresh batteries make the spinner go way too fast and it can actually make 10mL samples harder to see. I was actually going to look at a chemistry supply store and see if I could find some micro-sized stir bars as the one that comes with the unit is really too fat. It would be better if the stir bar was about half its current diameter.
    Matt
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    There are a number of different sized ones available through smile.amazon.com
    Apr 2011
    Murrieta, CA
    2,360
    eBay is also a good source
    May 2015
    14,094
    Quote Originally Posted by pabeader View Post
    I just ordered a bunch of stuff yesterday. I'm rocking Amazon Smile. Already got $5.50 donated this year. Lee's going to take his kids to Dairy Queen for sundae's ...
    Matt
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,153
    You got me beat, I'm at $4.48 so far. He can get one too!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,419
    Love my Apollo Speed Stirrer, unfortunately they don't make them anymore
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Paul & Crystal's Avatar
    May 2014
    Oklahoma City, OK
    539
    I love my Taylor speedstir. I play "She Blinded Me With Science" by Thomas Dolby when I use it .
    60K 53 X 23 X 3'-10' IG Grecian Concrete aka "The Beast"
    TF100 XL with Speed Stir
    Dolphin M500 aka "The Beast Master"
    Sta Rite Max E Pro 2 HP - Hayward Pro Series Sand Filter S310T.
    My Pool Thread: Old School Pool
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Quote Originally Posted by Paul & Crystal View Post
    LOL! How many times we saw that on MTV? ....LOTS!!
    Essential Links:
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    I remember the first time I used the TF-100 and without a speedstir.
    Getting dark out, had the kit out on the deck by the pool, mosquitos buzzing
    around and eating me alive while I was trying to do water tests on my first
    home with a pool.
    Then I realized i could just test inside and i did get the speedstir immediately
    and have been much happier about testing since.
    Dolphin E10 Cleaning Robot.
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    I also love the speedstir. It is great for testing.
    My only complaints are:
    1) If the vial gets a bit wet on the outside and leaks onto the stirrer mechanism, the vial will actually start spinning along with the stir bar.
    2) When the batteries get low on power, the stir bar starts acting a bit erratic and jumps around.
    3) Emptying solution out without loosing the stir bar is a bit tricky. I may get a small aquarium fish net to strain through to catch the stir bar each time.
    Otherwise, it is the "Cat's Meow"!
    19328 Gallon Above-Ground Pool. Clean&Clear Pentair Cartridge Filter. Opti-flo 2 Stage 1.5hp Pump. Dolphin Nautilus Plus "Flipper" Robot. Established April 2016. Taylor K-2006. Chlorine Based. 340gallon Marquis Spa. Bromine based. Established 2007.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    I use a small plastic cup to drain my vial into. If you hold it at a very flat angle, you can empty the vial without losing the stir stick. And if you do, it's pretty easy to retrieve.
    May 2015
    14,094
    I just stick my hand into the garbage disposal when I drop the magnet in. As long as my mother-in-law isn't around, I feel safe enough to do that
    Matt
  20. Back To Top    #20
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Essential Links:
