Thread: First time using TFP test kit, my results.
    Jan 2017
    El Cajon
    6
    I know I have hard water, that is evident by the scales on my tiles. I thought I would share my test results and see what y'all thought and the direction I need to go.
    FC = 13ppm
    CC = 0
    Total Chlorine 13ppm
    CHT = 1,075
    TA = 40
    CYA = 70
    Forgot the smaller test kit within...
    Here are the results from that.
    pH = 6.8
    CL = 5+ a bit darker yellow than the top reading
    BR = 10+ again, a bit darker yellow than the top reading
    I am looking forward to your responses and insight.
    Thanks, Coob
    Pool and in ground jacuzzi / approx 31500 gals
    Pentair 3/0 HP Variable Speed Pump
    Pentair Fiberglass Diatomacesous Earth Filter
    Pentair Solar Touch Control System
    Hayward Heater
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Re: First time using TFP test kit, my results.
    PH level is important to help control your scaling issues. What's yours!
    30,949
    Yep, we need pH also post pH, TA and CH of your fill water
    Jan 2017
    El Cajon
    6
    Added additional information, but TA and CH? Do we have the same kit?
    Hayward Heater
    Jan 2012
    'burbs of Augusta, Georgia
    8,576
    Is this the kit you have?--> TFTestkits.net
    We ask folks to list their current test results in this fashion for ease of interpretation:
    FC
    CC
    pH
    TA
    CH
    CYA
    TA=Total Alkalinity
    CH=Calcium Hardness.... I've never seen anyone refer to it as CHT?
    Also, unless you actually *have* a Bromine pool you don't have to pay any attention to that side of the pH block. Just the pH.
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Jan 2012
    8,576
    Now, on to the test results- Your pH is entirely too low particularly if you have a heater. This is also probably why your TA is so low. Your CSI per PoolMath is in the corrosive range. This needs to be addressed pronto!
    Do you have a Salt Water Chlorine Generator? How do you sanitize your pool???
    High Calcium is not unusual for folks out west, between the hard water and the evaporation, the CH tends to climb. It can be managed but if you can drain about half of your water and replace it with fresh fill it should help.
    Pool School - Calcium Scaling
    Yippee
