Thread: Verify the correct CH target...
    Question Verify the correct CH target...
    Here's where I'm currently at:
    Test Reading
    FC (ppm) 5.5
    CC (ppm) 0.0
    pH 7.6
    TA (ppm) 70
    CH (ppm) 190
    CYA (ppm) 75
    Salt (ppm) 2000
    SWG (ppm) 2700
    Temp 62
    According to the water balance documentation, CH needs to be around 350-450. Just got back from my local pool store where they were saying it really shouldn't be much above 200. Yes, they know I have a plaster pool. Which is it and what's your best guess as to why the other source is saying otherwise?
    Thanks!
    Rich - 21k gal IG pool/spa, pebble, completed Sept 2016, no water restrictions
    - Hayward: EcoStar pump, SwimClear C5030 cartridge filter, T-CELL-9 sanitizer, H400FDN heater, ProLogic controller
    - Acc: Polaris Vac-Sweep 280 Black Max F5B cleaner, Hayward 6060 booster pump, Taylor K-2006/K-1766
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,241
    Re: Verify the correct CH target...
    Rich,
    Look at your CSI...
    Using your numbers above you are at -.76 or corrosive
    Increasing your CH to 450 drops you to -.34 and increasing your pH to 7.8 gets you in the -.16 range...
    You only have two choices.. believe the Pool Store or us... and remember, we are not trying to sell you anything...
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    There's our answer. Best guess on their answer?............cause it's their "best guess".
