Thread: Removing Rust and Other Stains
    Oct 2016
    Los Angeles, CA
    16
    Hi. This forum is the greatest thing since the invention of the swimming pool. I've had great advice from here. We bought our home last year, which came with an old but structurally sound in-ground pool. It's age is showing, though. I'm posting to ask how I can remove rust stains and other marks from the surface. Here's a photo. https://photos.google.com/share/AF1Q...otX2tXUy0zUHR3Any suggestions? Do I have to drain it and repaint it? Hope not. Thank you!
    32' x 16' x 8.5' heated IG, plaster, rectangular pool with attached spa. Pentair Intelliflo 2 VST Variable Speed Pump. 36-gal DE filter. Teledyne Laars heater. One skimmer drain and one floor drain. Connected spa with two jets and floor drain. Approximately 40 yrs old.
    JoyfulNoise's Avatar
    May 2015
    14,083
    Re: Removing Rust and Other Stains
    Have you identified all the stains as metallic? Any organic staining?
    Also, if metals are present you need to find the source or else treating the pool for stains is a lot like pouring oil into a car engine with a leaky crank case seal - you're just masking the problem.
    Matt
    Oct 2016
    Los Angeles, CA
    16
    I'm not sure how to identify the stains by type.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,994
    A vitamin c tablet rubbed on a metal stain should fade a metal stain. If it doesn't, then it isn't likely metal staining. A chlorine puck rubbed on an organic stain should fade an organic stain.
    Try those methods is a good place to start.....and post back with results, questions
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    More info here,
    Pool School - Pool Stains
