Thread: Electrical question concerning a Sundance Cameo hot tub
    Aug 2016
    Montreal, Quebec, Canada
    32
    Hello TFP members!
    Our Sundance Cameo hot tub came with an add-on SWG - which is awesome!
    The spa is serviced with 240V; a power cord carries current from the main controller panel to the SWG unit, which also runs at 240V.
    Once the snow finally melts, I am planning a minor change to the SWG, and I would need it to run on 110-120V, instead of 240.
    Question:
    Can I expect to be able to run a 110-120V line from the controller to the SWG, replacing the existing 240V one?
    In other words, does the controller have clearly identified headers with voltages so that I can know where to connect to?
    We're still deep in snow right now in Montreal, and it's not possible for me to access the controller to take a look!
    Thanks in advance!
    Ron
    Sundance Cameo portable Spa, 370 gallons, 101oF, cover on when tub not in use, Taylor K-2006 test kit;
    FC: 2-5 ppm; CC: < 0.5 ppm; pH: 7.6; TA: 45ppm; CH: 125ppm; Borates: 50ppm;
    tucsontico's Avatar
    Mar 2014
    227
    Re: Electrical question concerning a Sundance Cameo hot tub
    Quote Originally Posted by presse55 View Post
    Hello TFP members!
    Question:
    Thanks in advance!
    Ron
    Not sure if I've ever seen an SWG that runs on 110V. However, do an internet search for the Sundance Spa Owner/Installation Manual. Usually there is a circuit diagram included (my Coleman/Maxx spa has one) in the manual that details the connections to/from the controller. Good luck!
    19,500 gal, 16' x 38' PebbleTec IG Pool, Built 4/2013; Pentair IntelliFlo VS 3050 3 HP Pump, Pentair Intellichlor IC40 SWG, Pentair IntellipH, Pentair 520 sq ft/150 GPM Cartridge Filter, A&A In-Floor Cleaner, Dolphin Nautilus Plus Robot (aka "Robbie"), Pentair EasyTouch Power Panel w/ Quick Touch 4 Remote Control, Autelis WiFi controller, Clear 12 mil Solar Cover on Presto SS Reel, Taylor K-2006 Test Kit.
    JoyfulNoise's Avatar
    May 2015
    14,080
    I would contact the manufacturer as I really doubt this is possible.
    The internal plates of an SWG typically need anywhere from 24-32V DC to generate chlorine, not AC voltage. So the input voltage (240VAC) is typically stepped down by a transformer and then rectified (AC is converted to DC). So I really doubt you can change the input voltage to the SWG system without affecting the cells performance, or worse, damaging the voltage converter. Sometimes electrical systems are designed with a jumper that allows one to choose 120VAC or 240VAC as the input voltage source but that is something that has to be intentionally designed as part of the electrical system and it would be obviously located near the input power connection.
    Matt
    Aug 2016
    32
    I just found a schematic - don't know if this helps.
    I have a sneaky suspicion that no 120V service is available from this controller.
    Regards
    Thank you for your replies.
    JoyfulNoise: you are right on all points. My SWG does have that jumper, allowing it to operate on either 110V or 240V.
    Also, my intention is to bring this 110V line to the SWG control unit, and not the electrolysis plates.
    So by feeding SWG control unit 110V from now on, I would simply select the jumper setting to reflect this.
    And yes, the DC current to the plates I have measured at around 25VDc in the past.
