Results 1 to 9 of 9
Thread: New to SWG. What size SWG?
    May 2016
    Carthage, Il
    47
    So new to the SWG idea, but if we went with the Hayward T-15, what parts/components EXACTLY do we need?? Is there a separate electric box that goes with it too??
    27', round, above ground pool, hard side, vinyl liner, 22" WaterWay sand filter.
    Jul 2014
    Hope Mills, NC
    618
    Re: New to SWG. What size SWG?
    Yes there is. Its just a piece of pipe without the controller.
    Apr 2016
    Riverview, FL
    351
    Here's complete system, you'll need to choose specific cell based on pool size.
    Free Form 13K IG (Quartz) w/Screen Enclosure - 2 Sheer Descents, 1 Bubbler - Hayward 60 SF DE Sta-Rite - Hayward SP3400VSP EcoStar - Hayward Aqua Rite AQR9 (T-Cell-9) SWG - Zodiac MX6 - July 2016 - Taylor K-2006 - Taylor K-1766 Salt Test
    May 2016
    Carthage, Il
    47
    I'm not sure what you mean? Pipe? The link I've attached is what we are looking at. I really don't want to spend $1,000 for a SWG!
    https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,975
    It says it is for pools up to 18,000 gals. How many gallons does your pool hold? If possible we say to try to over size your SWG to help save the cell replacement BUT that sure is a good price and I like it has the timer inside it.
    I hope someone that has this one comes along to say how they like it.
    Kim
    May 2016
    Carthage, Il
    47
    Ours is 19,000 I think. The reviews on Amazon had several that had 20,000 gallon pools and they said they had no trouble with the product and had it for several years. I like the price too!!
    Jul 2012
    Tallahassee, FL
    33,975
    This is something where you have to think short term over long term cost. The reviews are good and it is Amazon so they have a great return policy so..............do what you think is best for you at this time in your life then tell me how much you love it!
    Kim
    Apr 2016
    Riverview, FL
    351
    Quote Originally Posted by bethdorothy View Post
    The rule of thumb is to have a cell that is at least twice the size of your pool, that one is not.
    You'll end up running the swg cell almost all the time and will result in needing to be replaced sooner since it will run more often than a properly sized cell. If you run at 100% for just your regular pool maintenance level you won't have any overhead left when you need higher chlorine production. But do what you think is best for you.
    JoyfulNoise's Avatar
    May 2015
    14,091
    While it is true that you should oversize the cell to maximize cell life, the real benefit is pump run time. Remember that an SWG only produce chlorine when the pump is running and it only can create a fixed amount of chlorine per day. So, if the amount of chlorine produced is not sufficient to replace the amount of FC lost every day, you will be running your pump 24x7 and still have to add bleach. That will cost you more in higher utility rates as well as extra chemicals.
    While the price of an SWG seems high, you are essentially buying all the chlorine it produces upfront rather than paying for it with each bottle of bleach. The economics of bleach versus SWGs is pretty much a wash - either pay for all you chlorine up front or spread over time.
    Matt
