Thread: Leaking union?
    Mar 2017
    SC
    5
    Leaking union?
    I unscrewed this to wash out the filter and when I tightened it back it leaks now. I did not see an O ring and can't see the model of the pump to replace it. Would I be able to use plumbers tape or another method to prevent the leak? Any steps on how to fix it would be appreciated. Thanks.
    Jan 2012
    'burbs of Augusta, Georgia
    8,585
    Re: Leaking union?
    Skippy suggests that you look up the schematic for the hayward pump you have online and see if it calls for an O ring or flat gasket. He thinks for sure it should have, being that its under pressure.
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Apr 2015
    tucson, arizona
    1,312
    Re: Leaking union?
    That's the Hayward NorthStar pump. The part is the SPX3200UG union gasket
    Mar 2017
    SC
    5
    Re: Leaking union?
    Quote Originally Posted by kadavis View Post
    Thank you so much. Just ordered it
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Leaking union?
    Some silicone o-ring lube, aka plumber's grease, will help stop a leak.
    Re: Leaking union?
    It looks like the glue joint is leaking and dripping down. Wipe dry to confirm.
    Support the site
