Results 1 to 9 of 9
Thread: algae or pollen?
    Dec 2016
    spring hill fl
    19
    algae or pollen?
    The water temp is 65
    I have a Taylor kit k2006
    Fc is 3.5 cc is 0. (All winter long)
    Alk is 110
    Cya is 75
    Ch is 340
    My pH runs high 8.0 but I check it bi monthly in winter to keep it at 7.6
    Yet 8 weeks ago i noticed what looked like mustard algae in a corner. Pool gets full sun. I brushed it off. I came back about 9+ days later. It brushes right off. Comes back a few weeks later. Today it was on most of the bottom. Clogs filter. I've cleaned it 3 times in 6 weeks. Slimy stuff. I sprayed it with deliuted bleach this time. I do have lots of pollen. It floats on the surface but I did not think it sank.
    Pool Finished 2013 13.5K rectangular plaster. 3.5' on ends, 5.5' in center
    Solar (connected to EasyT)
    Pentair Easytouch 4 Two Body System w/ remote
    Pentair 3HP VS pump, IC40 SWG, 150 Cartridge Filter
    30,954
    Re: algae or pollen?
    Sounds like your flow throughout the pool may be a little inadequate. Got a pic of the pool water? Have you done an OCLT?
    Dec 2016
    spring hill fl
    19
    That was my thought. I keep the pump at very low speed. Just enough the enable flow sensor on swg. I do not know how to add a pic. But the water is very clear. The last thing you mention I do not know what that is.
    OCLT ok I see. I can do that. I check it even in the winter. It has always been steady at 3.5-4
    30,954
    Pool School - Perform the Overnight FC Loss Test (OCLT)
    Reread it. It is a test for chlorine loss over a period of time.....not a static measurement
    Have you read "The "ABC's of Pool Water Chemistry" up in Pool School?
    Dec 2016
    spring hill fl
    19
    Yes. I understand. Was just saying I do check the chemistry in the winter months. I see that this test could let me know if I have alage or something else. I did increase the pump speed to help skim the pollen off the surface better.
    Thank you
    Dec 2016
    spring hill fl
    19
    Tested 6:00pm : fc 5 cc 0
    Tested 8:30am : fc 5 cc 0
    No loss of chlorine. So you can test for algae. What a huge tip. When I was new to this the pool store would tell me you can't test for algae. I haven't been there in 2 years.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Quote Originally Posted by thomspool View Post
    Good answer!
    Dec 2016
    spring hill fl
    19
    You guys were spot on with filtration issues. I soaked the filter in dishwasher detergent and that made a huge improvement. I would rely on the pressure guage to indicate cleaning time but just a few psi increase did not indicate that the outflow was so low. You think adding an additional gauge elsewhere would help me monitor the outflow?
    DFW, TX
    24,974
    There is a better gauge available for cheap at TFTestkits.net. We recommend cleaning when the pressure rises 20-25% above clean pressure.
