Thread: Plumbing questions
    Mar 2017
    CO
    69
    Plumbing questions
    So I've had my eye on this 18' x 33' x 54" pool from poolfactory: https://www.thepoolfactory.com/saltw...3x54-oval.html Reason: Seams like the lowest price salt water capable pool that I can semi bury apx 27". If anyone has a different suggestion/recommendation then please let me know.
    Question #1: The pool specs don't say how many drains/returns it has. Unless I wasn't able to find it, I'm assuming 1 drain (skimmer) and just 1 return. I've been reading here at TFP that so many pool owners have more than 1 drain and more than 1 return. Is this a pool manufacture count or do all/most pools only have 1 of each and the installer chooses to increase this? Is it just as simple as putting in a Y connector in the return line to split a return into 2 ?
    I have not picked out my pump/filter but will most likely be going with a 1.5hp 2 speed pump & sand filter. I'm also interested in a SWG and doing 2" pvc piping and buying the piping and locating the pad apx 25-30' from the skimmer.
    Question #2: I have never installed an in ground pool before. Can I choose to put the return anywhere or is the return hole already cut out of the side walls? I want to locate the skimmer in the NW corner of the pool and put the return in the SE corner of the pool to promote water circulation.
    Thanks !!
    Mar 2017
    CO
    69
    Re: Plumbing questions
    bump
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Much of what you are interested determining related to included drain/skimmer/returns is listed in the installation instructions of prefab pool kits. I am sure the seller can discuss additional plumbing questions with you. Sorry I don't have the expertise on above ground kits to help you further.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
