Results 1 to 11 of 11
Thread: SWCG v. Regular Cholorine System Intitial price difference
    Dec 2016
    Douglassville, PA
    49
    I'm an in-ground pool newbie getting ready to have a pool installed at our home this Spring. We negotiated price, plans, etc prior to finding this forum (its awesome by the way). The system quoted by the PB is for a regular chlorine system with a frog. I've certainly seen the negative comments on the forum regarding the frog and have also seen a ton of positive comments from posters and friends of mine who have SWCG's that has pursuaded me to explore the option of making the change in equipment now and going with a SWCG. I also understand from reading the forum that long term the SWCG is not necessarily more expensive when compared with daily chlorine, chemicals, etc. So, my question is not based upon the lifetime cost of the system, but more what I should expect the "upcharge" to be if I were to change out the equipment to a SWCG. The question is to just make sure I've budgeted enough $$$ for the build out as the costs keep mounting (i.e. Need for retaining wall, need for relocating my septic line, need to completely redo the fencing around my property, etc.).
    Also, I'd love some suggestions specifically related to my pool as to what SWCG equipment you would recommend for my pool build. Currently looking at a 650 square ft free-form pool (may upsize to 700-750)....still up in the air. Our proposal provides for an electric AquaCal SQ120R 120,000 BTU heater if that makes any difference. Also quoted Aquabrite finish.
    Thanks in advance and let me know if you need any more into to help in making your suggestions!
    Happy Weekend to all!
    Pool Completed Spring 2017: 650 sq ft (26,000 gallon) IG free form (depth 3'-8'). AquaBright Finish (Blue Lagoon). Jandy DE Filter (DEV60). Jandy VS Pump. AquaCal SQ120R Heat Pump (110,000 BTU). AquaCal Autopilot SWCG. 1600 sq ft concrete.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,248
    Re: SWCG v. Regular Cholorine System Intitial price difference
    P,
    Whatever SWCG you buy, make sure it is 2 x the size of your pool. So if your pool is 20K gallons, then you need a SWCG rated at 40K..
    This is because they rate SWCG's when running 24/7 at 100% output. You really don't want to have to run them full out all the time.
    My guess on cost is that the SWCG system will cost your PB about $1.5K and he'll sell it to you for $3K.. But this is just a guess...
    Jun 2011
    Long Beach, CA
    2,889
    As Jim said it is important to at least double the rating size of SWG compared to the actual gallons in the pool.
    You want to stay with the same brand of SWG as the rest of the equipment if you have any plans for automation. If there isn't a plan for automation, then there are many brands of SWG to consider.
    Expect to pay from $1000 to $3000 depending on your contractor and system you decide to get.
    Dec 2016
    Douglassville, PA
    49
    Ping just to clarify, would that be $1000-$3000 above the cost of the regular chlorine system quoted with my pool (i.e. Frog). Sorry if these seems like a dumb question.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,892
    Quote Originally Posted by psualum View Post
    Probably. Remember, the pool builder is probably getting a "deal" on the Frog hardware because they know you will then be locked into purchasing stuff down the road (kind of like the razor handle is free, because it only fits one manufacturers blades). So thte Frog stuff may be little to no cost to him, but for the SWCG expect to pay full retail plus additional labor (including planning).
    Expect push back from the builder. They seem to like to do things one way and discourage clients from doing other things.
    A recommendation on a SWCG may depend on other equipment you plan on getting. One speed pump, two speed pump, variable speed pump, manual valves, automated valves, complete automation system, type of filter, brand of heater and other little details may factor into the equation.
    Support the site
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    That would be the cost, instead of the frog system. Not sure what thay would charge for the frog.
    How long do you think your swimming season will be? That might be a factor in this decision. Also, do you plan to keep the pool open all year or do a traditional closing?
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Dec 2016
    Douglassville, PA
    49
    Pa.....our season is basically May through Oct. We will be closing the pool for the winters which can sometimes be harsh here. Sitting on about 10 inches of snow right now.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    Hhmmm... 6 months. So a SWG makes sense. That's good then. I will tell you this; I really like the convenience of my SWG, but if I didn't have it, I would do plain bleach (liquid chlorine) before I would even consider some alternative sanitizer.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,493
    Just a heads-up that the frog system is not a regular chlorine system, but rather relies on metal ions together with chlorine to help prevent algae. This thread is worth reading, along with others you'll find: Pool Frog question/opinions
    I love SWCGs because I prefer not hauling chlorinating liquid. You could let the PB get his kickback from frog, then cut it out and replace it with a SWCG for under $1500 if you DIY. If your PB doesn't balk at the change, he probably gets the SWCG cheaper than retail and it's easy for his pool plumber to add it when doing the rest of the plumbing, but it makes sense he'll want to make money, so the cost would be higher. I saw you mention a two-speed pump, which means a two-dial timer or two-speed pump timer. You can run the SWCG off the same low-speed timer and make everything work well. Good luck and congratulations on deciding to put in a pool!
    You'll find it useful to provide pool gallonage and features, with the full equipment list here. There are people here with a ton of experience, and they'll steer you toward trouble-free equipment choices. Part of what makes TFP a great forum is that the experts and mods don't let any hogwash go unchallenged. You can say 'proposed' and add the pool description in a signature, then modify the signature if/when things change. And don't worry, people here respect that it's your decision at the end of the day
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Dec 2016
    Douglassville, PA
    49
    Thanks all!
    Needajet, thank you for the info regarding the timers, etc. With regard to the signature, I will update that but don't know exactly what the pool gallonage will be yet. Don't have the drawings back yet. I will go in and try to add what I know though, which I'm sure will change. Any thoughts on Pentair vs. Jandy?
    needsajet's Avatar
    Jan 2016
    4,493
    Hayward, Pentair, Jandy all good. If you're talking SWGs, all get good reports here. Circupool sometimes gets recommended here, though you'll find older threads from when Circupool SWCGs were made by CompuPool (pre-2012), when they had more than their share of problems. There are several active members here that are happy with Circupool, but the others are the market leaders.
    As earlier mentioned, if you want to eventually automate, choose the preferred automation system first, even if you're not buying it now. Then work back to select pump, then SWCG, then anything else, e.g. heater, acid dosing, lights, etc. The automation system will be the most trouble free and easy to install if the components are all from the same brand.
    Great to see the signature! Thanks You can enter '20-25K' gal for now.
