Thread: How to fix this valve
    Mar 2017
    Houston, TX
    1
    So I have a pool that was built in 2003, and this valve, that adds water to the pool when the water level is low, is leaking. When I opened this valve, water started flowing into the pool, but when I closed it, water kept flowing in. I think that the stopper is old and corroded and would like to replace that as I think it would be a fix. What is the piece that I'm holding in the below picture called and how would I find a new one?
    Also added a third picture that shows the overall setup.
    Thanks for your ideas and suggestions.
    May 2016
    Naples, FL
    17
    Re: How to fix this valve
    The parts you are holding in your hand are what i call the stem and packing nut. The whole valve is a gate type valve. If you could find the manufacture name on the body, you may be able to find parts at hardware store or plumbing supply. I think the cheapest and easiest is going to just get a new valve from hardware store, Home Depot, Lowes, etc. Looks like you would have to cut the PVC enable to thread on new valve, so you will also need a couple PVC fittings.
    12,000 gal Free Form gunite/plaster pool, Sta-rite Cartridge Filter, Pentair Easytouch, Pentair Intelliflo, Pentair IC40 Intellichlor
    Apr 2015
    tucson, arizona
    1,314
    In the long run you might want to replace the valve and what appears to be a vacuum breaker above it with a PVB (pressure vacuum breaker) like this https://cdn3.volusion.com/7j5ob.q34u...jpg?1476367678
