Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: Foreclosure and now I have all zeros and stuff...
    Mar 2017
    Texarkana, TX
    11
    Question Foreclosure and now I have all zeros and stuff...
    Howdy, first post.
    I bought a foreclosure a year ago and has an in ground pool. The prior owner really let it go and had to have a lot of concrete work, new liner, etc. It was up and running around June and the guy who did the repairs added a SWG and I only had to add water and an occasional bag of salt. It started getting green a couple of times so threw a few bags of chlorine stuff which cleared it up.
    I had a back injury in October which put me out of being able to do anything, much less do house repairs and keep up with the pool. Now that I'm back up and going after surgery, I need to clean the swamp that's developed.
    Best I can tell from my dinky Home Depot kit (yeah, I need to order a real one from TFP):
    FC=0 (never turned yellow)
    Bromine=0 (same as above)
    pH=~7.3
    TA=60
    CH=100
    CYA=~20 or 30
    It's green and got stuff swimming in it...
    It's easy enough to dump a bunch of Clorox in it but was wondering what would be my best path to getting it ready. I've been tempted to order a 12pk of di-chlor as it would fix my chlorine and CYA at the same time from what I've read.
    25k, IG vinyl, Hayward sand, Breeze SWG, Polaris 280, floor drain, one skimmer
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,951
    Re: Foreclosure and now I have all zeros and stuff...
    HI! I know your pain as we bought a foreclosed home with a pool also BUT did not know about TFP at the time so spent MUCH money on getting it fixed and ended up draining it Sorry to hear about the back in injury. I hope all is well now.
    I would NOT add the bags of stuff as it will raise your CYA. The more CYA you have in the water the more FC (free chlorine) you will need. For right now your CYA is purrfect for a SLAM. Here is the link to it:
    Pool School - SLAM - Shock Level And Maintain
    The most important part of the SLAM is the M as in Maintain the FC at your SLAM level for you CYA of 30.
    Please take a picture of the pool looking down at the steps. Do this each day to help you and us see your progress.
    we will get your pool looking like a jewel with chlorine and time!
    Kim
    Mar 2017
    Texarkana, TX
    11
    Thanks for the pointers.
    Took the net out last night and skimmed everything I could off the top.
    I dumped 3 3/4 gallons of 8.25% bleach in at lunch and started the pump.
    Will be home later and hopefully will be able to see the bottom again at some point, can fish out other debris then.
    triptyx's Avatar
    Apr 2016
    1,476
    That's a pretty impressive frog habitat you have there!
    Let's get to SLAMming and we'll help you to achieve a nice clear pool. Stay the course!
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    For the chlorine to even have a chance, you are going to have to clean out all that debris. Not sure which net you have. To make it easier to clean up the bottom, they make one with a bag shaped net that can collect an impressive amount of 'stuff' even when you can't actually see the bottom.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    How about a photo so we can see your pump equipment?
    Dolphin E10 Cleaning Robot.
    Mar 2017
    Texarkana, TX
    11
    I've got this leaf net:
    https://www.amazon.com/ProTuff-Pool-...=pool+leaf+net
    Works really well.
    There isn't that much debris on the bottom. I know what's there as I was going to get the stuff out but a friend of my dad came over and put the net out for me because of my back. I'm sure some additional has fallen through the mesh but shouldn't be insurmountable.
    Tested and it dropped down to about 7FC last night so dumped some more in. Didn't have a chance to test this morning before I had to leave for work, but did backwash.
    Getting a little better:
    http://imgur.com/CstZDHb
    Pic of the equipment (have close-ups if desired):
    http://imgur.com/x44JR6K
    Jan 2012
    'burbs of Augusta, Georgia
    8,577
    Oh the water is looking better already!
    If possible, at least try to do a chlorine dose in the AM, another as soon as possible when you come home, and a last one right before bed. The more often you can dose, the faster this will go.
    Its going to look great when you're done
    Yip
    Addendum: Daily pics right over those white steps are going to show you your progress best.
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Mar 2017
    Texarkana, TX
    11
    Here is yesterday morning:
    http://imgur.com/iQcxeJb
    And this morning:
    http://imgur.com/XE1WwL3
    Doesn't seem like much of an improvement from last night.
    My chlorine levels last night were about 14, didn't have a chance to check this morning. It should be clear of most debris now, except for what I can't see to get the remnants of.
    How of a chlorine level can I safely get without damaging equipment or the liner? It "feels" like I need to add more bleach, but hesitant to get to aggressive and hurt something.
    I've been backwashing twice a day, in the morning and at night, I assume that's enough...
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    The amount is completely based on your CYA level and this chart: Pool School - Chlorine / CYA Chart
    Since you are SLaMming you will use the shock column of non-SWG. The SWG part is there for once you are done with the SLaM.
    There is no harm is being a little above the number, but it really doesn't give an added benefit.
    Mar 2017
    Texarkana, TX
    11
    I'll double-check my CYA today and make sure it's not higher than what I first thought.
    I've been keeping my SWG turned off while doing this. I assume that's the correct course of action?
    domct203's Avatar
    Jun 2015
    CT
    3,898
    Quote Originally Posted by BadBack View Post
    Howdy, first post.
    pH=~7.3
    TA=60
    CH=100
    CYA=~20 or 30
    Welcome to the forum!
    ....... My chlorine levels last night were about 14, didn't have a chance to check this morning. It should be clear of most debris now, except for what I can't see to get the remnants of....
    My apologies if it's been mentioned, but I didn't see you mention if you have a FAS/DPD test. You can't SLAM without it.
    You definitely have your hands full, but you you'll beat it!
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Yep, for now SWG off is the best course of action. No reason to to use up some of it's life at this time.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    This will be a good one!
    As for backwashing, it may and likely will be a lot more than that up front. Can you tell what shape your filter pressure gauge is in? You need one you can rely on as this will tell you when you need to backwash. Once you have a proper kit, and have the Pool ready, following a SLAM procedure will fix this for you. Lots of people will be ready to help with any questions or problems you may have. Good luck on it!
    Essential Links:
    Mar 2017
    Texarkana, TX
    11
    Quote Originally Posted by domct203 View Post
    I have the tftestkits.com $70 thingy.
    Measured at lunch and down to about 11FC and 30CYA.
    Dumped another gallon of 8.25% bleach in. "Feels" like stuff should be dying more quickly.
    Running the pump 24/7. I'm not expecting it to clear up quickly, but would expect it to be less green...
    And while I do have a newish gauge, something may be screwy with it. I'm normally running 13-14psi after a backwash and the pressure goes down the more it's used...When it reaches about 10 psi or so I backwash it. I would expect that to be backwards and a greater change in psi...Any pointers on what I've got going on there?
    Mar 2017
    Texarkana, TX
    11
    Hey folks, getting a little discouraged.
    Have had the pump running 24/7 for coming up on 7 days today and still really green with no hope in sight.
    I've added DE, brushed twice a day, kept the FC above 12, etc. with no luck. I'm tempted to dump another two gallons in to see what happens but scared to damaging the liner or something.
    What am I doing wrong? I've vacuumed as well and have removed as much debris from the bottom as I think is possible. I can't see more than a foot under the surface.
    Here's what it currently looks like:
    http://imgur.com/KQVamdf
    With all the backwashing and vacuuming and topping off the water, surely my CYA has dropped even further, meaning I should be needing less chlorine, but doesn't seem I'm making a dent.
    What do I need to do?
    Jan 2012
    8,577
    How often per day are you dosing?
    I think rechecking your CYA is prudent here.
    Are you using fresh high quality bleach of at least 8.25%? No bargain bleach or bleach from Lowes/HomeDepot/Dollar Store......right??
    Yip
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    10,729
    Please post a complete set of current test results. Are you still backwashing daily?
    Love TFP? Become a
    TFP Supporter!
    Sep 2016
    Escondido/CA
    641
    I was just reading a different SLAM thread where it took over 3 weeks, so more patience will get you there. What you are fighting is the existing algae making more nearly as fast as you kill it off at first. The dead algae also clouds the water making it seem all that much more murky too.
    However, keep at it, keep dosing, and it will work. The more diligent you are, the less chance it has to fight back, and the quicker you will win the battle. Said another way, a steady SLAM level works better than overshoot, undershoot, overshoot, undershoot.
    Also, once it passes all three criteria, you may want to just keep it going for a couple days to make sure you have completely vanquished your enemy.
    Jon -- 28kgal, IG, AquaBright, Attached Spa, ~1990, Quad DE 80, Easytouch8, IntelliFloVS-3050, Intellichlor60, IntelliPh, Dolphin DX6, City Water, K-2006/TF-100, SpeedStir, SampleSizer, San Diego, CA
  20. Back To Top    #20
    30,950
    When a pool is algae laden.....chlorine will kill it. Honestly, that pool looks like it has never had any chlorine in it.
    Are you vacuuming and brushing? are you keeping the FC continuously at SLAM value?
    Chlorine is always the answer. Use it evenly but make sure it is in there ALL the time.
    Are you running the pump 24/7?
    A little overshoot on your FC won't hurt but keep it reasonable.
    Your pressure decreasing as you run the pump makes no sense. What triggers you to backwash the filter?
