Thread: Does pool pump need to be running for heater to work?
    Mar 2017
    Houston, TX
    86
    We are turning on the heater for the first time. It seems to make sense for the pool pump to be on for the warm water to return, but we didn't get specific instructions on this so just double checking! Thanks!
    First time pool owner
    21K IG; quartz plaster finish
    Pentair 1HP Whisperflo pump; Pentair Clean and Clear Plus cartridge filter; Pentair Mastertemp 400K BTU heater
    Polaris 280; Completed Feb. 2017
    Jan 2013
    Long Island, NY
    184
    Re: Does pool pump need to be running for heater to work?
    If hooked up correctly, the heater will need to detect water flow in order for it to turn on. So to answer your question, yes the pump will need to be running.
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,241
    JYH,
    Yes, the pump has to be running. The heater has an internal pressure switch that needs to be closed...
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Yes, heaters have a pressure switch to check for water flow as a safety feature. Heaters cannot heat without water flow or they will overheat and break stuff.
    Mar 2017
    Houston, TX
    86
    Ok got it - thank you all for the quick replies!
