Results 1 to 8 of 8
Thread: Heater Problems
    Jun 2016
    Austin, TX
    335
    Heater Problems
    I have a Hayward 400k BTU heater that seems to work fine, if i can actually get it to ignite. Sometimes it will fire up right away but it seems most of the time it tried and then i get an IF error and it kicks into service mode. If I press MODE and switch it back to pool, it will try again and eventually it will light and work fine. Does anyone know what I should troubleshoot first? I know nothing about heater internals.
    Thanks!
    13k Gallon IG Pebble w/ attached Spa, AquaRite T-Cell-15 SWG, Hayward DE6020 Filter, Hayward 2 HP Pump, Hayward 400k Heater, TF-100 Kit, Pool Logger
    ps0303's Avatar
    Jul 2011
    FL
    3,920
    Re: Heater Problems
    Guessing this is an ED2 unit? I would have to guess you have a bad control board. Seeing that if you mess with the mode key it will light off and work. Many times the connection on the board for the ignitor breaks off or becomes unsoldered and thus you get results like you are seeing.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    TexasDeano's Avatar
    Aug 2015
    Frisco, Texas
    137
    Re: Heater Problems
    I have a Pentair heater that was starting and then shutting off after 10-30 seconds or so. It turned out to be the water flow sensor tripping the shutdown. I resolved it by speeding my pump up when I ran the heater. Not sure if is even close to your issue, but I though I'd share in case.
    18'x24' Rectangle (3' 6" to 5' 5") - 11K gal. Saltwater w/ Blue Granit Pebblesheen
    Pentair equipment (IntelliFlo 3050 VS/SVRS Pump, 60 sq. ft. DE filter, Intellichlor Salt system, MasterTemp 400000 BTU heater
    Easy Touch 4 w/ Screen Logic automation, 3 GlowBrite LED Pool Lights) My build log
    Jun 2016
    Austin, TX
    335
    Re: Heater Problems
    It is a Hayward h400idl2 if that helps
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Re: Heater Problems
    Based on the information provided I would check the gas train first. Could be as easy as removing and cleaning all the orifices. Spiders like to get in there and block the gas flow to the ignitor. When you have an IF code that normally means insufficient fuel. Could be blocked gas line, bad ignitor, or gas valve. As always I recommend this be checked out by a heater technician.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    tech@hayward.com
    Jun 2016
    Austin, TX
    335
    Re: Heater Problems
    Thanks! I have someone coming out tomorrow because it flat out stopped working with an A0 code a few days later.
    ps0303's Avatar
    Jul 2011
    FL
    3,920
    Re: Heater Problems
    Sounds like a possible blower motor issue. Good luck if it is as they are not easy to come by plus consider the age of the unit and putting any $$ into it at this point.
    Paul
    Mar 2017
    Cypress
    5
    Re: Heater Problems
    TexasDeano. I have the problem you are describing on my pentair 400. First it would fire up for about 12 sec. I replaced the stack flue sensor since I received an E05 error. Now it fires up for about 25 sec. And shuts down. Is there a water flow sensor that can be replaced?
