Results 1 to 13 of 13
Thread: Space bar issues?
    jasnovanorder's Avatar
    Jul 2015
    Hamilton Michigan
    201
    Space bar issues?
    Is anyone else having issues when replying with a quote that the space doesnt work when typing? Had that on a couple different threads. Replied with a quote and had to type the whole reply as one loooooong word then go back and put the spaces in. Works fine here but not when replying.
    Intex AG metal frame vinyl sides 10,400 gal. 3000 gph intex pump with 16" sand filter
    My Slam
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,155
    Re: Space bar issues?
    No issues here.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,542
    By any chance are you using Google Chrome?
    aggiewonder's Avatar
    Feb 2017
    Spring, TX
    42
    Quote Originally Posted by jasnovanorder View Post
    I had this happen once...but now it works. Google Chrome browser.
    Still finding out details, new owner of used pool.
    13k, inground, plaster, Pentair IntelliFlo pump, cartridge filter, cooler, IntelliTouch i7 & AquaRite SWCG. TF-100, K-1766 & SpeedStir. More details as I learn...
    Jul 2015
    Hamilton Michigan
    201
    Quote Originally Posted by Leebo View Post
    Yes I am. It was fine making this thread but goes all kitterwhompus making this reply
    My Slam
    Jul 2011
    Eastern Ohio
    7,542
    I was just able to recreate this issue in Google Chrome and see your settings match. This issue appears to mostly occur to Chrome when the user is using the WYSIWYG option, which I see both of you are currently using. To work around this please follow this path,
    General Settings > Miscellaneous Options > Message Editor Interface > Standard Editor
    Please change that setting and let me know if that works to address the issue.
    Jul 2015
    Hamilton Michigan
    201
    Lets give it a go. Nope still no bueno
    My Slam
    Notseeinganyproblemshere.
    Support the site
    Jul 2015
    Hamilton Michigan
    201
    Quote Originally Posted by JamesW View Post
    My Slam
    JoyfulNoise's Avatar
    May 2015
    14,083
    I'm currently usingWYGWYAI when adn I try tpo type and use font embellishments like bold oritalics and backspace inside the embellishment, it cause problems....
    Now WYSIWYG mode is turned off and it doesn't matter if I use backspace or not....
    Turn off WYSIWYG mode....
    This was done on a Chromebook running the latest version of Google Chrome .... and it happens on my Mac too in Safari
    Matt
    triptyx's Avatar
    Apr 2016
    1,476
    I have this issue as well (also have the problem with it jumping the cursor to a random location if I use backspace after having added italics/underline/etc). I'll try turning off WYSIWYG.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Hmmm, my Android Tab works perfectly at all times.
    Apr 2016
    Riverview, FL
    351
    I use Chromebook and thought it was an issue with my system. Turned on the standard editor and looks like it's working find now. Thanks for raising this.
    Update ----- I was typing a reply to anothermessage and found that while better, thespacebar issuedoes remain with the standard editor (as evidenced by this update).
    Free Form 13K IG (Quartz) w/Screen Enclosure - 2 Sheer Descents, 1 Bubbler - Hayward 60 SF DE Sta-Rite - Hayward SP3400VSP EcoStar - Hayward Aqua Rite AQR9 (T-Cell-9) SWG - Zodiac MX6 - July 2016 - Taylor K-2006 - Taylor K-1766 Salt Test
