Thread: OCLT (not SLAMing)
    Nov 2016
    Melbourne, FL
    139
    OCLT (not SLAMing)
    OK, so we had a ton of rain. The pool has had a tinge of green to it the last few days, crystal clear though. I am coming off of a SLAM and I have 8.5 FC, 0.0 CC the last few days, and a 7.6 pH. Planning on doing an OCLT tonight, since the pool is clear. Should I leave the pump running or not.
    Full Chemistry
    FC 8.5
    CC 0.0
    pH= 7.6
    TA= 95
    CH= 290
    CYA= 65
    NaCl=3200
    15K Gal Gunite Pool, White Pebble Surface (unkown), Pentair Intelliflo Variable Speed Pump, SunTouch automation, sta-rite plm100 filter, Hayward AquaRite AQR-15 SWG.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Re: OCLT (not SLAMing)
    That sets off the metal (iron) alarm. Are you on a well? Did it turn green quickly? How long has it been green?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Nov 2016
    Melbourne, FL
    139
    In the morning it looks blue, but full sun of the day has a green tinge to it. Not sure if is a reflection off the house into the Blue Granite Pebblesheen causing an appearance of green.
    My fill water is municipal water.
    Quote Originally Posted by Mr Bruce View Post
    Nov 2016
    Melbourne, FL
    139
    My big question, is an OCLT test valid if I don't run the pump all night, but run it again for an hour in the morning before I take the second reading.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Yes, that is ok as long as you mix in the chlorine when you add it the night before and mix again in the morning.
    Nov 2016
    Melbourne, FL
    139
    Woke up, tested after circulation system running an hour.
    FC 9.5
    CC 0.0
    No overnight chlorine loss.
    The pool looks great in the morning, but by mid afternoon has a green tinge to it. Like I said not sure if its an optical illusion with light reflecting around.
