- Mar 9, 2017
- 141
- Plaster
- Pentair Intellichlor IC-40
Well I guess it was bound to happen sooner or later. Had some low numbers and tried to bring them up. Missed it.....by a lot. Just want some opinions on RE adjusting so I don't screw it up again. I got the calculator readings if you think I should just follow that.
#'s BEFORE
FC .8
PH 8.0
CYA 60
ALK 80
CH 240
#'s AFTER
FC 7.2
PH 7.0
CYA 60
ALK 50
CH 240
Calculator says to add 2.5lbs washing soda (PH)
Also 10 lbs Baking Soda (ALK)
So I did the over add about 24hrs ago pumps been running aprox 8 hrs of that on med speed.
I love a learning curve....Doh!
Thanks
Jedisparky
Sent from my 2PS64 using Tapatalk
#'s BEFORE
FC .8
PH 8.0
CYA 60
ALK 80
CH 240
#'s AFTER
FC 7.2
PH 7.0
CYA 60
ALK 50
CH 240
Thanks
Jedisparky
