Results 1 to 8 of 8
Thread: Getting pool ready
    Jun 2016
    Central Oklahoma
    83
    Getting pool ready
    How much should I drain?
    May/2018 AGP Coleman 24x52 vinyl, 13.6k gallons, Harris H1572228 Vortex 16 inch Above Ground Sand Filter System with 3/4 HP Pump, PoolBlaster Max, TF-100
    Run pump 24/7
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,884
    Re: Getting pool ready
    Well it depends what your levels are. You can SLAM it to get it back under control. Look in my siggy for the SLAM link.
    Kim
    30,941
    I see no reason to drain anything. Get a STRONG leafnet and get out everything you can. then, SLAM the pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Jun 2016
    Central Oklahoma
    83
    That was the conclusion I decided too. Waiting on a Hayward Skimmer, then will get it filled and pumps going. Before test.
    Run pump 24/7
    Jun 2016
    Central Oklahoma
    83
    Cant run pump much when at work skimmer basket gets full fast. Dont have that much time to vacuum. Brush daily hopefully it will be clear shortly. Really love this way of life.
    Test results are:
    24'fc
    Ph 9
    Ta 100
    Ch 300
    Cya 15
    Added 5.5 lbs Cya
    Added 45 oz muriatic acid
    Run pump 24/7
    Jun 2016
    Central Oklahoma
    83
    Yeah, still had 14 fc in my pool this morning. So, much better than 1.
    Run pump 24/7
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Good work.
    If you catch your FC below 10 you might want to check pH. Starting high, and with 100 TA it may rise up pretty quickly again.
    Essential Links:
