Thread: Stenner replacement tubes
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    243
    Will the #2 tubes fit in the MPHP5 pump with #1 tubes? It's been about a year I guess and I should think about replacing them. What's the flow on the #2's? Not much info on Lockes website.
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    243
    Re: Stenner replacement tubes
    NM i found the answer
    22,703
    Glad you found the answer, but for others who may be looking for the answer. Yes, the #2 tubes will fit the #1 pump. In fact any of the tubes will fit any of the pumps. The only caveat is that if you have a HP (Hi Pressure) pump and use one of the low pressure restricted tubes, you effectively create a low pressure pump because of the pressure rating of the pump tube.
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    243
    Literally took 5 minutes to change.
