Results 1 to 16 of 16
Thread: Choosing a Pool Finish
    Mar 2017
    Fort Worth, Texas
    137
    All,
    I'm currently working with a few different pool builders in the DFW area on a pool for my Mom and Dad. The bid we like the best is listed in my signature. My only concern is the use of the Aquabright pool finish. There doesn't seem to be a ton of info about it (I have found one thread about someone who built it and loved it but that was posted last year and my concern is longevity) especially with regards to how it would lasts. Other builders are quoting Durazzo, Hydrazzo and Primera Stone but at slightly higher prices than the Aquabright (my family has extremely tender feet and we have to have a very smooth pool finish). Anyone have any insight into the lifespan on this product as it doesn't seem to have been around all that long? I would prefer the Aquabright as it has the smooth texture and is naturally inert reducing the amount of chemicals to properly maintain it. Here's the link to the company's website. Below are some renderings of what the pool would look like. http://www.ecopoolfinish.com/
    22X40 31000 gallon IG. AquaBright plaster, Jandy 2hp epump, 60sqf de filter, Aquapure 1400 SWG, Polaris 965, jxi400 propane heater, iaqualink control, 2 Watercolor LED lights, Taylor K2006, My Build Thread
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,606
    Re: Choosing a Pool Finish
    That's a good point on the longevity. I was under the impression it should last at least 2 to 3x as long (if not longer) than plaster
    from a standpoint of being polymer based. As long as proper chemical levels are maintained reasonably. There is a resident
    aquabright guy on the forum. BDavis i think is his name.
    Have you looked at all the aquabright threads on this forum?
    I just had a new liner put in last year so it will be awhile before I need it replaced, but I'm considering aquabright as the next
    step when it's time.
    Dolphin E10 Cleaning Robot.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,149
    Drop "aquabright" into the search box and you will come up with numerous threads on the topic which are current and detailed. User bdavis466 is a licensed Aquabright installer who is very objective in his discussions here. This is an article written by him.
    http://watershapes.com/pools-spas/we...ibilities.html
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mar 2017
    Fort Worth, Texas
    137
    I've only found 2 threads, one testing it's resistance to scratching, algae, chemical's etc... and the one person who had the pool installed with it last year.
    It seems like it should last as long as an exposed aggregate at least, but a few competitors are convinced it will be falling apart long before that. Could just be professional jealousy on the part of the competition, but I always like to do a lot of research before a relative puts down that much money.
    Oct 2012
    Quakertown, PA
    56
    Quote Originally Posted by benm2010 View Post
    It could be jealousy. It could also be wise discretion. It is a newer product and I dont think its possible to find anyone with it in a pool that is 15-30 years old in order to test the claims that are made. All the science and preliminary data are there in order for the claim to be made.....but I dont think its been around long enough to see if the claims are able to be held up in real life.
    Sep 2016
    Escondido/CA
    641
    I have Aquabrite; but just got it last fall. I expect it to last for a few reasons.
    It is comfortable to sit on, and smooth feeling, but can be put on with a bit of roughness [if you like] if you have something you want to be anti skid.
    I would suggest you take a look at the tests Brian did; I can't find them just now but will look later if no one else answers. He has put samples of Aquabrite in highly acidic solutions and in pure chlorine as well as some other tests.
    To give you some insight into how tough it is, when it was getting applied, a small section had to be ground off and filled [about a dime-sized divit]. It took the guy, with an angle grinder, and a coarse diamond cutter about 20 minutes to grind it off. He fought it all the way. Not because it can't be cut with diamond, but because it is so very tough. If anyone ever wanted to get the Aquabright off, I think the substrate it is attached to would have to be chipped out.
    I have heard that there are some that will give a lifetime warranty, and if you see it and feel it you will understand why. It is a thick, tough thermo-deposited inert plastic coating, bonded with semi-cured epoxy.
    Since it each layer is melted into the next, it is repairable. An example I can think of might be damage from a falling tree. Lets say that gave it a good scratch, or cracked the underlying gunite. Once the substrate was repaired, another coat could be blended back into the existing coat, and since it would be melted into the previous layers, it would be as good as new.
    https://www.troublefreepool.com/thre...-Washing/page4
    But the most important reason to get Aquabright is, if you are lucky, you might get to use the flamethrower!
    Jon -- 28kgal, IG, AquaBright, Attached Spa, ~1990, Quad DE 80, Easytouch8, IntelliFloVS-3050, Intellichlor60, IntelliPh, Dolphin DX6, City Water, K-2006/TF-100, SpeedStir, SampleSizer, San Diego, CA
    Mar 2017
    Fort Worth, Texas
    137
    Quote Originally Posted by xyz View Post
    this is awesome information and makes me feel much better it. Love the color on that pool as well.
    Sep 2016
    Escondido/CA
    641
    Another side benefit that I didn't realize I would appreciate as much as I do is that the water is staying remarkably stable. So stable that I'm not checking it often enough! I have my PH automation set to 5%, and I'm not even sure I need that. I *think* that since there is no interaction with stone/plaster/aggregate/cement/etc. there is no issue with leaching calcium out of, or onto the surface (this is not 100% true since I have grout around the tile, but 99% true]. I still scrub the sides once in a while, but the robot seems to get those; so I think I'm just going to go with scrubbing the places the robot can't get.
    I had huge calcium issues before hand, so I probably appreciate it all the more. But if you are worried about durability, I would not. This is exceptionally tough stuff.
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    3,872
    I can understand the skeptical approach to a newer product and especially one with so little information out about it.
    AquaBright was just about unheard-of on this forum so that's why I put together the Plaster and Aquabright Comparison thread. I was impressed enough that I became an installer and that was never my intention. That thread is pretty unbiased since I was nothing more than an inquiring mind at the time.
    If you have any specific concerns let me know and I'll experiment on a pool that was just finished. There isn't much you can do to hurt the surface that wouldn't also damage plaster and pretty much nothing can be done that can't be undetectably repaired.
    -Brian-
    Pool/Spa, Pentair Equipment
    Mar 2016
    McKinney, TX
    176
    I wish I had known about AquaBright last year when we built our pool, I might have tried it. I think that they used it on the lazy river they built at the Frisco Rough Riders stadium (minor league baseball team) here in DFW. At least I thought I saw the flamethrower in some of the construction pics they posted on Facebook. I want to check it out! We went with Primera Stone but I'm really intrigued by this whole Aqua Bright thing.
    17K gallon, 18x40, 107 perimeter, 550 sq ft gunite inground pool with raised spa. 3.5 ft. - 5.0 ft. - 4.0 ft depth. Pentair equipment. DE filter. English Walnut travertine paver decking, lueders limestone coping. Wet Edge Primera Stone Sapphire Treasure plaster.
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    3,872
    The biggest disadvantage is the price but quality isn't cheap and cheap is never quality...
    While I have no factual proof, it certainly looks like this finish may eventually pay for itself due to less maintenance and chemical needs.
    -Brian-
    Mar 2017
    Fort Worth, Texas
    137
    Interestingly enough, AquaBright installer is actually the cheapest bid (most other's were using durazzo as the finish) and I feel confident in it, especially with PB's reputation. In a similar thought does anyone have the Cool Deck finish on their decking? Have been getting mixed reports about the durability and effectiveness of it?
    This thread is fantastic. I absolutely love having a direct comparison between the two.
    Quote Originally Posted by bdavis466 View Post
    Sep 2016
    Grand Prairie TX
    50
    benm,
    Our pool completed end of 2016 and probably the same PB you are leaning towards. For me, I'm glad we ended up with this PB who highly recommended AquaBright. Of course, I know more now than I did then but I was fortunate I made that decision to go with it. As bdavis says, the chemical balance and upkeep seems much easier for AB than the others.
    One question, why are you not going with a Saltwater pool? That is just as big a decision as the AB one, IMO.
    19x32 Freeform Gunite IG pool, 14,500 gallons, 3.5 x 5 x 4, 313 sq ft decking, AquaBright(Blue Mist), 2.0 HP Jandy EPump,Cleaner Booster pump, CV 460 SqFt Jandy Cartridge filter, Aqualink w/PDA, Fusion-Salt System, 2 LED, Jandy Heat/Cool Pump 140K BT, Polaris 3900 w/Pump My Build
    Mar 2017
    Fort Worth, Texas
    137
    dgknight3,
    Pool is for Mom and Dad and Dad is not a huge salt fan. They are used to using the 3" pucks from the above ground pool and since they back wash relatively often and will be running well water the stabilizer in Tri-Chlor isn't really an issue. The upfront cost and then replacing the salt cell every 3-5 years seems more complicated than keeping a tube filled with the pucks since they are already used to it. Most of the builders I've talked to have actually advised against the salt system with the Oklahoma Flagstone coping as they say it is corrosive to it. Mom and Dad are both elderly (64 and 73 respectfully) so I'm attempting to make their life as simple as possible.
    Sep 2016
    Grand Prairie TX
    50
    Ahh, I see your reasons for the decision. I missed that from the first post.
    Feb 2016
    Flower Mound, TX
    45
    Brian i will testify to this. In the last year I've bought two 4lb containers of CYA. One 5 lb container of CH, One 4 lb container of pH up and one 40 lb bag of salt. My chemical cost is almost non-existent. Water stability is AMAZING. So much so that I'm "forcing" myself to check once a week. And that is mainly to determine my FC so I can adjust my SWG. I grew up with a traditional puck pool and as a teen did much of the maintenance, what a pain.
    I think AquaBright + SWG is truly a very low maintenance situation. Love it. I suspect without it being physically damaged it will last decades.
    If I didn't have trees dropping leaves into the pool I wouldn't have to do anything but sit in the sun and enjoy.
    Edited: PS. I was in the same boat when we were deciding on finish. Not a lot of reviews out there. Which is why I started my longterm review thread. I did remember finding somewhere where SeaWorld put it through a test and was very impressed with it. i think they installed it in one of their facilities.
    9,000 gallon, IG, Ecofinish AquaBright pool finish, Jandy CV340 CF, VS Jandy 2hp e-Pump , Nature2 Fusion Soft SWG, Polaris 380 cleaner w/booster pump, Taylor 2006
