Results 1 to 8 of 8
Thread: Complete Pump Change Suggestions
    Nov 2016
    Houston, Texas
    3
    Hello- Over the next few days, I need to completely replace an old Blue Haven SmartMax Star Pump 2.7/.33; 2.5/.30 MRHP 1.10 SF (SP3220X252BH)
    What are some of the options you'd suggest?
    Many thanks in advance.
    23,000 gallons, IG-Plaster, Spa, Hayward Cartridge,
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,248
    Re: Complete Pump Change Suggestions
    TH,
    Welcome to TFP... A Great resource for all your pool questions.
    I am an unashamed Pentair kind of guy. In my opinion, the "Gold Standard" for pumps is the variable speed 3 HP Intelliflo. All the other pumps are almost as good...
    Just as a reference, I run my pump at 1,200 RPM most of time, 24/7, for less than $20 per month.
    Thanks for posting,
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    10,725
    Hi, welcome to TFP! A google search on SP3220X252BH pulled up a Hayward tristar pump. Any of the major pump manufacturers will give you a good quality pump, the question is what all does the pump need to do? Do you have water features such as fountains or waterfalls, roof top solar heating, bubblers, pool slide, or deck jets? Do you prefer a single speed, 2 speed, or variable speed motor?
    Love TFP? Become a
    TFP Supporter!
    Nov 2016
    Houston, Texas
    3
    Jim-
    Thanks for your warm welcome! I've heard great things about Pentair so I can clearly see where you're coming from. Especially, with those savings!
    Nov 2016
    Houston, Texas
    3
    Hi Zea3- Great questions. Outside of spa overflow into the pool, there's not really much that I'll need the pump to do. The past 2 years, I've used it on single speed and that seemed to work perfectly fine but I'm open to options. Is there anything in particular that you'd suggest? I'd prefer to stay under $600 but I understand the investment, if needed. Thanks again!
    Aug 2016
    Riverside, CA
    378
    Check for utility rebates on Variable Speed pumps and look at long term operational costs.
    Jul 2009
    Houston, Texas
    10,725
    If you were happy with the performance of your old 1 hp pump I would go with something similar. If you don't plan on installing an automation system I would go with a 2 speed 1 hp pump from any of the major brands. I would not go bigger than a 1.5 hp pump. A Hayward may fit in your plumbing layout without too much alteration to the existing pipes.
    Love TFP? Become a
    TFP Supporter!
    Kamil's Avatar
    Nov 2013
    Lancaster, PA
    45
    I see that the utility company in my area does have rebates on pumps, but it looks like it has to be installed professionally. That sucks. I'll have to do more research or open a pool service company
    Kamil
    28K gal installed 1985, IG Vinyl, Jacuzzi Sand Filter ST-24 (60 GMP) DVK-7 Valve, Jacuzzi Magnum Plus pump
