Thread: Considering a Polaris 280. How does the black in Black Max hold up??
    Murfreesboro, TN
    92
    Hey Guys,
    Pool #3 being built. Wifey wants a darker liner this time, and i was thinking about a Polaris 280 black max.
    Had 280s on both previous pools and i like em.
    Wondering if the black will fade as most other things do...........
    PB said: "there's a reason most boats are white.................
    Experiences? Thoughts?
    Thx
    Cal C.
    20k ig vl, hayward 2sp Tristar, hayward pro series sand filter, ecommand 4 with aqua connect, hayward heat pump, polaris 280 cleaner, TF-100.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Considering a Polaris 280. How does the black in Black Max hold up??
    Buy a robot. There are losts of them out there. They clean better and you don't need the pump (any pump ) to run it so they are much cheaper to run.
    Jul 2012
    Norco, CA
    3
    I had a Polaris 360 in black. It looked fine in the water but when pulled out and dried the black was quite faded. I wouldn't get another black one though simply because the replacement parts in black were several times more expensive than the white.
    ??k gal, IG plaster, spa with spillover, de filter
    Jul 2013
    Prosper, TX
    133
    I am just having to replace my 4 year old 280 black max. It did a good job, but just had a wheel snap off (not in a fixable way). The base was faded to a light gray. The wheels were still black, and the rest was faded a bit. The bag had recently been replaced.
    18,600 gal, IG, Jandy 60 sq ft DE filter, 2HP VS pump
    Stonescapes Tahoe Blue mini pebble
