Thread: Waterproofing a DIY poured concrete spa/baptismal
    Mar 2017
    Bridgton Maine
    1
    Hello pool/spa pros
    I'm picking up with a DIY project where someone left off. I need all the advice I can get on waterproofing the inside of a poured concrete structure which will be used as a baptismal at our church.
    The structure is 8' X 8' X 3' deep and is under a platform so only the inside can be seen. The structure is above ground so no pressure from water from the outside.
    Help!!!
    Thanks!!!
    getting ready to finish a diy poured concrete baptismal
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,933
    Re: Waterproofing a DIY poured concrete spa/baptismal
    Has an engineer looked at it to make sure it is safe for water? If so there is a new product called aquaBright that might work for you. Do a search and see what you think.
    Kim:Kim;
    30,950
    If you need to continue DIY, do you have any masonry skills? If so, I would simply plaster it. You have a great work area and a small enough job so you could finish pretty quickly. Plenty of you tube videos.
    Jan 2013
    Long Island, NY
    184
    I can't believe I am going to mention this, as I can't stand the commercials, but.....
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    LOL!! It turns a screen door into a boat. That could actually work, especially if it is left empty for periods of time. Pretty easy touch up too if needed.
    Jan 2013
    Long Island, NY
    184
    Quote Originally Posted by pooldv View Post
    It's like a handyman, in a can!
    TF-100 test kit
