Thread: 0 free chlorine level!
    Mar 2017
    Weeki wachee florida
    1
    I have a zero free chlorine reading With 5 total chlorine.
    PH is at 7.6 Alkalinity 130 calcium hardness 320 stabilizer 100 and total dissolved solids of 600. Of course the local pool store is telling me that I need phosphate remover. But first they want me to Lower my alkalinity with Ph down.
    My pool is an inground 12,000 gallon plaster chlorine pool with a pop up cleaning system . I just opened it after the winter. I've already given it 5 gallons of shock. Can anybody help me with this problem? Thank you I really appreciate it .
    Chlorine Plaster in ground pool with spa. 12,000. Gallons. Southeastern Florida. Pop up filtration system
    30,963
    Re: 0 free chlorine level!
    Welcome to the forum
    What are you testing with?
    May 2011
    lebanon tn
    370
    Total chlorine of five indicates the bleach you add d is beginning to work. Need complete good test results and add more bleach to get fc up
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Jun 2014
    17,346
    As Dave noted above, we first need to know how you got those test results. If it wasn't from a TF-100 or Taylor K-2006C test kit, that really needs to be priority #1. Do NOT spend any money at the pool store. Those products off the shelf will do nothing. Most chemical adjustments can be done with simple household products (see the links below in my sig). With your own tester, please post future test results up & down as follows:
    FC
    CC
    CYA
    pH
    TA
    CH
    It helps our old eyes. Once you have (or confirm) the proper kit and understand basics of testing, you'll be surprised how easy it is to maintain your pool. Oh, and welcome to TFP!
