Results 1 to 7 of 7
Thread: Anyone use a Suntouch Automation?
    Jedisparky's Avatar
    Mar 2017
    L.A. CA
    101
    Looking into an affordable Automation package to just run my Intelliflo VSP and SWGC IIC60. Anyone have any input or experience using Pentair 520820 SunTouch?
    Mike
    Loc: So Cal Full Sunlight, IG 30'x15' Rectangle, 21,000gal w/ 2100gal Jac w/ Spillover
    (SWG) Pentair Intelli IC40, Pentair Intelliflo Variable Speed UEE Pump
    Pentair Mastertemp 400 Pool and Spa Heater
    Pentair Clean and Clear Plus Cartridge Filter CCP-420
    Intellibright 5G Color Pool and Spa Lights, Hayward Nav Pro Pool Vac, Taylor-2006
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Anyone use a Suntouch Automation?
    Suntouch is the cheapest way to do that. It also has a spa mode and can control your heater.
    Jedisparky's Avatar
    Mar 2017
    L.A. CA
    101
    I've also been checking into Pentair IntelliTouch Load Center Sub Panel 521213 or Pentair 521213 Intellitouch Load Center for Pools with IntelliChlor Transformer. All I can find under $600, just figuring what most users like or experience are with these products.
    DFW, TX
    24,974
    All Pentair automation works the same. The difference is in the features and the amount of stuff it can control or add on. It is easy to say oh, how about some more.
    Suntouch is the lowest base model
    Easytouch is next and probably most popular here on TFP (you would probably want Easytouch 8)
    Intellitouch is the top end automation
    Jedisparky's Avatar
    Mar 2017
    L.A. CA
    101
    Right, back to the Easytouch as previously discussed. That's probably looks like the one. Thanks again.
    Jedisparky's Avatar
    Mar 2017
    L.A. CA
    101
    Alright! I have decided! Drum roll.........Pentair Easy Touch Control Base System 520538. Looks like this will be just what the Dr. Ordered, just have to figure out what part the PB will help out.
    Regardless I'm going to buy it and if I have to I'll put it in myself it's not going to be that difficult.
    DFW, TX
    24,974
    Alright, sounds good, congrats!
