Results 1 to 17 of 17
Thread: Sports pool centre depths
    Mar 2017
    ON
    19
    Those with sports pools with a centre water depth of 5 feet and play volleyball....do you find the net to be too high?
    I am 5'6", husband is just over 6'. Most friends are at least 5'6".
    We are leaning towards a sports pool with water depths of 4,5,4.....there will also be a small entrance in with steps to 3.5 deep (small stick out of the L shaped pool).
    Thanks for your input!
    Apr 2013
    Sacramento, CA
    2,769
    Re: Sports pool centre depths
    This is personal preference. Most prefer 5 foot center depth and 3.5 on the ends. That allows for more children's play.
    Jun 2016
    FL
    901
    I would recommend against 4' in the shallow ends as that would put the majority of your pool at 4.5-5' which is an unusual depth. We did 3.5/5/4 and wish the 4' was 3.5'. The only way 4' might work is if you have a really long pool (ours is 34'). It really boils down to personal preference on how you will use your pool. We are more social pool people than "swimmers" per se.
    The 5' middle is fine, as most of the time your playing back from the net.
    Brian - UNDER CONSTRUCTION: 17K gal SW Gunite IG. 17'x23'(w/shelf)x34'. 650sf. 114' perim. 3.5'-5' depth sports pool. 7'x11' sun shelf, 6'x8' spa. Intelliflow VSP, IC60 SWCG, CC420 filter, 4 LEDs (2 Globrite and 2 Intellibrite). Hayward 140K BTU heat pump. Pentair EasyTouch 8 automation. Ivory travertine deck. 8"X16" travertine coping. NPT lightwaves Aquamarine spa tile and marker tiles. Undecided on plaster/pebble finish.
    triptyx's Avatar
    Apr 2016
    1,475
    Quote Originally Posted by grumpiebk View Post
    Interesting! We have a 3.5/5/4 and I'd really rather it be a 4/5/4 as the 3.5 seems too shallow to stand and relax in.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    We have 3.5/5.5/4
    I wish we would have gone 4/6/4
    The 3.5 feels a little shallow (I'm 4'11") and 5.5 is too shallow to jump into without smacking your feet. Still a playable depth in the middle since you aren't right up on the net. Just my opinion..
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Jun 2016
    FL
    901
    Quote Originally Posted by triptyx View Post
    Curious, what is your pool length and how quickly from the sides does it start to slope? Ours starts to slope after just a couple of feet on a 34' long pool, so only a very tiny bit of our pool is actually 3.5. I think the slope could make all of the difference.
    Mar 2017
    ON
    19
    Thanks everyone, appreciate all the feed back. Pool length is 36 feet but I am not sure where it would start sloping towards the 5 foot centre. I am waiting for PB to call me back. I assumed that the three sections wold be divided out to be equal so for instance if the pool length is 36 feet....does 12 feet per depth make sense so 12 feet long of a 4 foot depth, then a 3 foot long slope down to the centre 5 foot depth...then a 3 foot long base of the pool at 5 feet depth and then mirror the rest of the pool to match what I just outlined. Does this make sense?
    This morning I woke up with another idea....since we have kids (almost 1, 3 and 5) there is a part of me that does want a bit of a deeper area for them to jump into.....so would the following work - extend the pool length to 38 feet long. Use the first 24 feet length for volleyball (12 foot long sides)....is 24 feet long enough for a full court say with 4 on 4 players? At the 24 foot mark slope it down to 6 or 7 feet (whatever permits based on pool code for slopes and depths). No diving board obviously but just an area for jumping in, cannonballing. Mostly it would be a social pool as I am not a big swimmer....husband is more so than I but doesn't want diving depths.
    I can't seem to attach a picture of the project but below is our design video.....backyard is a blank slate except for an existing deck which is just getting extended. I wish I would have found this site earlier......so many helpful and knowledgeable people!!! Thank u thank u thank u!
    pearlstone v5 0 - YouTube
    Last point....shape of pool is L because I wanted a large shallow end at the base of the L and then a deep end branching up off the L but since the base part is only 10 feet wide it won't work as a true shallow end for volleyball if that makes sense.....
    triptyx's Avatar
    Apr 2016
    1,475
    28 feet long. I'd say at least 4 or 5 feet is the 3.5 foot depth, but you're right, it may be less than 3.5 near the end.
    Our little ones are ok cannonballing (no head first diving is allowed) with the 5 foot center - I'm not sure you're going to like the utility of trying to go to 7 or more feet, but that's something you can certainly ask your builder about.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,149
    Be careful when comparing comments from gunite pools versus liner pools. It is common in liner pools to have flat areas with constant depth before the slope occurs. Gunite pools more commonly have constant slopes of varying degrees. Note the types of pools people have from their signatures and factor that into their replies.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jun 2016
    FL
    901
    Quote Originally Posted by Apearl View Post
    Thanks everyone, appreciate all the feed back. Pool length is 36 feet but I am not sure where it would start sloping towards the 5 foot centre. I am waiting for PB to call me back. I assumed that the three sections wold be divided out to be equal so for instance if the pool length is 36 feet....does 12 feet per depth make sense so 12 feet long of a 4 foot depth, then a 3 foot long slope down to the centre 5 foot depth...then a 3 foot long base of the pool at 5 feet depth and then mirror the rest of the pool to match what I just outlined. Does this make sense?.....
    This seems really odd to me. A 3 foot length for a 1 foot drop is a really steep slope. It would be nearly impossible to stand on and not sure it would even pass code? Our continual slope from 3.5' to 5' over nearly 15 feet is noticeable. For a sports pool I wouldn't want it much steeper.
    A better option may be 5 feet of shallow end and then continuous slopes to the deepest middle point.
    As for your L shape pool, if you want to go with a real deep-end, why not make the small portion of the L the deep end? Then have your sports bottom in the long end of the L?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    We have 3.5x5x4. 4x5x4 is perfect.
    Mar 2017
    ON
    19
    Quote Originally Posted by bmoreswim View Post
    Excellent point!! I didn't realize that the slopes are different on the gunite versus vinyl pools. Ours would be vinyl.
    Mar 2017
    ON
    19
    I feel that it would be awkward to have the deep end near the main deck lounge area because the loungers wouldn't be able to interact with the people in the deep end of the pool and likely there wouldn't be as many people in the deep end as in the shallow. Also the loungers on deck would be getting splashed by the jumpers. Lastly this is the spot where we get the most sun ....it's the last spot at the end of the day to have sun....we have a north facing backyard.
    Mar 2017
    ON
    19
    Thanks Pooldv! I have been reading this....numerous older posts state this is prefered. I am struggling with the slopes though. My PB has never installed a 4,5,4. We are doing a vinyl lined pool. Can you please explain your slope across your pool? I am trying to understand how large these 5 foot deep sections typically are in these pools or if it is just a valley (lowest point) at which the pool then starts to back up to 4 feet?
    Last edited by Apearl; 03-17-2017 at 12:47 AM. Reason: Added name of poster I am commenting back to
    Jun 2016
    FL
    901
    This makes a lot of sense. I didn't appreciate your layout.
    DFW, TX
    24,974
    Our pool is gunite and it is a continuous slope from 4' down to 5'. Which is great because people of all heights can find their sweet spot for standing in the depth of water that suits them best. Our pool is 41' long so the slope is very gradual. The 5' part is only a few feet wide in the middle. I don't know if vinyl pools can be built with a similar gradual slope.
    Mar 2017
    ON
    19
    Thanks Pooldv for the explanation, really helpful and appreciated
