Results 1 to 11 of 11
Thread: Build Deck Over Sand Filter
    Deeannw's Avatar
    Jul 2016
    Bellevue Nebraska
    13
    Hi all,
    I've searched the forums and couldn't find an answer to my question.
    We have 24x52 round AGP with sand filter and pump. Brand new August 2016. We closed the pool and brought both the filter and pump indoors in October because we have brutal winters.
    So we are having a half deck built (12x8) and it will connect to our higher deck by stairs. The filter and pump will be under the half deck. Deck builder said we will have a hatch to access filter. So my question is, how will we get the filter out once the season is over or do we keep the filter outdoors under the deck? Or should we move the filter? Any thoughts would be greatly appreciated. Thank you!
    Dee Ann W
    24x52 round AGP 14750 gallons 19" Hayward sand filter w/1 hp pump Polaris 65 vacuum sweep (Hasn't worked since purchased) Transitioning from Strip test to Leslie's FAS-DPD 81329
    Mod Squad JohnT's Avatar
    SW Indiana
    9,327
    Re: Build Deck Over Sand Filter
    I don't know that there is any reason to bring it inside. Drain it, disconnect the plumbing, take the gauge off and plug the hole. Sun is much harder on the filter than cold and snow.
    But, someday you'll have to replace it, so there has to be some way to get it out of there.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    If it were me I wouldn't cover equipment that will need service where you will only be able to get to it thru a hatch. If its on the perimeter of the deck where you can access the equipment with out having to go under the deck that might be ok.
    Where is the skimmer going to be in relation to the deck?
    Pictures could be helpful for ideas.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    10,728
    If you decide to build the deck over the top of the filter and pump you will need to make sure you include a big enough crawl space to access both if needed. I would also hard plumb with ridged pvc pipe and get rid of any hoses connecting equipment to the pool. You can add valves to the pvc and you won't have to worry about how to access the hoses should one break or pop off.
    Love TFP? Become a
    TFP Supporter!
    Deeannw's Avatar
    Jul 2016
    Bellevue Nebraska
    13
    Thank you! I'm going to take pictures before the build. And I was wondering about the skimmer as well. My husband wants to leave a five ft area open on the side of deck. That makes no sense to me. I'll add photos. Thank you!
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    236
    If at all possible I would move it away from the pool to an area that is not under the deck. The pump and filter is something that you need to deal with on a regular basis, having it buried under the deck is going to get old. In a freezing climate with an above ground pool, you must be able to access the plumbing so everything can be disconnected and drained every fall then reconnected in the spring. It's about as easy for me to store my pump and DE filter to the basement where I don't worry about freezing as it is to be certain everything is thoroughly drained and safe. When I had a sand filter I always removed the control valve along with the pump for storage, then drained and covered the tank and sand. The skimmer must be easily accessible for cleaning or connecting the vac, a small access door would work for that as long as you can get to the plumbing from underneath to winterize. I prefer to be able to walk right up to the skimmer rather than get down on my hands and knees to clean it out every single day. I crawl around under the deck just to get the pool covered and closed in the fall, and that is more than enough of that.
    AGP 24' x 54" approx 14000 gal Full sun all day, Hayward 1.5 HP and EC50 D.E. filter
    Stenner 45MPHP10 10 gal/day fixed rate with intermatic ET1125C timer
    Dolphin E10 robotic cleaner, 330 gallon Tiger River Spa, Taylor K-2006C test kit
    Teald024's Avatar
    Aug 2016
    Lyme, NH, formerly Columbus, Ohio
    1,488
    Quote Originally Posted by Deeannw View Post
    Dee Ann W
    Congrats on the new pool and Welcome to the forum.
    I would seriously consider the weekly, if not daily, maintenance of the pump and filter. The pump basket will need to be checked & cleaned. The filter pressure will need to be checked and backwashed as necessary. Even with that hatch, you will be crawling around under a low deck trying to operate and clean the equipment. Don't forget your flashlight or you will have to crawl out to get it. I suppose if the equipment was just at the edge of the deck it wouldn't be as bad.
    Good luck
    Deeannw's Avatar
    Jul 2016
    Bellevue Nebraska
    13
    I'm including 2 photos. I've circled where the skimmer is and the sand filter goes on the concrete square. So the deck will be 12x8 and the skimmer will be in the middle of the deck. I wish I had known this before. And can we move the sand filter where the lavender x is? The deck will not be on that side. There is a retaining wall. I appreciate everyone's comments and replies!!
    Jul 2009
    Houston, Texas
    10,728
    You could put the filter where the lavender X is, you would just have a longer run of pipe from the pool to the filter. It may look a little odd since the pump and filter would be off to the side, but it should function just fine.
    Love TFP? Become a
    TFP Supporter!
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    I definitely would run plumbing to get your equipment out from under that deck. Either out to the purple x or out the back of the deck towards the white vinyl fence. Which ever is most convenient spot to work on them. Make sure you have really good access to your skimmer to you need to get to it not only for day to day stuff but also for winterizing.
    Chuck-
    Deeannw's Avatar
    Jul 2016
    Bellevue Nebraska
    13
    Thank you so much zea3 and CJadamec! I appreciate your comments and suggestions. We'll definitely put the filter and pump more toward the white fence. We're getting quite a bit of rain so we hope the builder can start the deck in the next week or so! Thank you!!
