Thread: Pool light niche gasket, caulking, recommendations?
    Apr 2016
    TX
    51
    Hi,
    I'm replacing my pool lights. I'm not 100% sure about the 1 retaining screw holding the light to the niche. Has anyone used marine caulking, or some sort of gasket, to give the niche some water protection? The fixture itself will be waterproof, but was wondering if anyone tried to make their niche a little less prone to ingress.
    Mo
    Mo - 21K gal, IG plaster, dual Pentair SuperfloXF pumps, 72 sqft DE filter, cartridge filter for the spa, dual Waterco multi-cyclone prefilters, Dual Circupool SWGs, Polaris booster and cleaner, TBD custom controller.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Pool light niche gasket, caulking, recommendations?
    The niche is designed to be flooded and have water circulate in it to cool the light.
    Apr 2016
    TX
    51
    Thanks Pooldv - good thing I asked before I glued stuff down.
    DFW, TX
    24,974
    that's what we're here for!
