Thread: New pool build - SE Pennsylvania - Decking question
    Dec 2016
    Douglassville, PA
    49
    Wife really likes stamped concrete look. Considering stamped concrete that cantilevers over the edge of the pool. Seems too look nice. Any thoughts on how the stamped concrete would hold up if we choose to go with a SWCG? Thanks in advance for educating this pool dummy!
    Pool Completed Spring 2017: 650 sq ft (26,000 gallon) IG free form (depth 3'-8'). AquaBright Finish (Blue Lagoon). Jandy DE Filter (DEV60). Jandy VS Pump. AquaCal SQ120R Heat Pump (110,000 BTU). AquaCal Autopilot SWCG. 1600 sq ft concrete.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: New pool build - SE Pennsylvania - Decking question
    Concrete decking will do fine with a saltwater pool. It is one of the most impervious materials available for decking.
    Sep 2016
    New tripoli, PA
    91
    I am also doing a saltwater pool in pa and I'm going with stamped concrete. Didn't hear any negatives other than the cracking
    Spring 2017 new build in PA ! //// Pool on a big hill //// IG SWG 800 sqft +100 sqft sun shelf + 50 sqft spa. //// All Jandy Pro series equipment (help me choose which models !) //// SGM River Rok or Diamond Brite (help me choose!) //// Stamped Concrete, Pavers, or Stone (help me choose ! )
    My Spring 2017 new build in PA ! //// Pool on a big hill //// IG SWG 700 sqft +100 sqft sun shelf + 50 sqft spa. //// All Jandy Pro series equipment (help me choose which models !) //// SGM River Rok or Diamond Brite (help me choose!) //// Stamped Concrete deck
    Oct 2012
    Quakertown, PA
    56
    Quote Originally Posted by psualum View Post
    Im in Quakertown - not to far from you. We are getting about 1500 sq ft of stamped concrete and a cantilever edge. Im not concerned about the SWCG at all. I was concerned about cracking. Concrete will crack - end of story....that being said, my PB uses a sub that puts a full 4+ of compacted stone below 4 full inches of the fiberglass additive and reinforced concrete. Then we chose a random stone pattern with non linear expansion joints cut into it. If/when it cracks - it isnt that hard to recut along the crack and die the edge and it will match up to the rest.
    Now...what I AM concerned about is how slippery it is. They are going to use a matte sealer with some sort of grip additive....but Ive heard that it can still be slippery. I may ask for extra, extra grippy stuff...
    I was pretty specific when I sat down with the different PB...and asked a lot of questions about how their subs did things.
