Results 1 to 7 of 7
Thread: SWG question
    jimmcg29's Avatar
    Mar 2009
    Lower West Michigan
    21
    SWG question
    I am considering a SWG this summer. I did some searching and I think a Circupool RJ60 for about 1K is my best bet. For the price and size, I feel pretty comfortable with that unless someone has any dire warnings about this company. I live in Michigan so it will only get so much use.
    That is not really my question. I have a 36K gallon pool so that seems to be a reasonable size. From my research on this board most advice is to get one larger than you need. This is getting to my question. From what I understand the reason to get the larger size is to last longer because you donít need to run it as much.
    I have a two speed pump that I run 24x7. Is it OK to run the SWG continuously? Of course I would adjust the amount of chlorine produced. So my question really boils down to does the life expectancy depend more on how long the unit runs or the amount of chlorine produced? If I produce x amount of chlorine in 8 hours is that better/worse than producing x amount in 24 hours. If I do plan to run it 24x7 do I still need to get the larger size?
    Thank you,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: SWG question
    Sorry to start with a question, but why do you want to run 24/7 from now on?
    Essential Links:
    jimmcg29's Avatar
    Mar 2009
    Lower West Michigan
    21
    Re: SWG question
    I thought the idea of a two-speed pump was to run it twice as long at half the speed. That would be pretty close to 24 hours so I just ran it 24 hours. It worked nice. If I get a SWG is a two speed not necessary? Or are you saying with a SWG I can run the pump even less?
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,496
    Re: SWG question
    The operating cost of a SWG arises from the cost of a replacement cell when the original one wears out, and the electricity to run the cell. Both costs are directly attributable to the amount of chlorine produced. Keeping your water TFP perfect will minimize scaling, including a likelihood of zero scaling. If you do get scaling and need to clean the cell, the cleaning will reduce the cell's lifespan.
    I would go the bigger one because of economics and because you'll have the option of turning it up for a kids birthday party (or when the dog goes for a swim ).
    Some people go smaller and then top up with bleach or chlorinating liquid, but for my money, running the SWG hard is the cheapest additional chlorine you'll ever buy.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Oct 2007
    Parkland, FL
    753
    Re: SWG question
    I run my variable speed pump at the lowest speed it will go and still power the swg for 6 hours a day. you are wasting a ton of electric.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Jun 2007
    Houston, Texas
    212
    Re: SWG question
    I run my pump 24/7 as well. My electric cost are extremely low in my area. I think continuously running the pump is better on the motor than stop and starting it each day. Plus, I get so much stuff into the pool that I rather skim everything round the clock.
    I put my SWG on 20% and it supplies enough FC for my needs. I don't know much about Circupool but I've seen good ratings. I'm sure it probably has a similar switch to turn it on a percentage of the time, so you can still run your pump but only run the SWG when you need it.
    36,000 gallon IG Gunite (40 x 20), 1.5 HP Hayward pump, Pentair Nautilus NS-48 DE filter, 2 skimmers, 12 - (2 x 20) Fafco Solar Panels (Goldline controller not hooked up yet), Hayward Swimpure Plus SWG, Blue Pearl Robot cleaner. New Dr. Wellness X-12 standalone Lifestyle Spa.
    Jul 2014
    Mesa, AZ
    3
    Re: SWG question
    I would avoid the Circupool product. I purchased the RJG 45 in 2013. In 2015 I began to have issues. I called Discount Salt Water pools where I purchased it. They referred my to the Mfr. in Florida to deal with my warranty claim for a failed controller. At first our email exchanges were fine. I filled out the proper forms and included photos of the failed controller. They eventually stopped communicating and responding to my inquiries and never provided me with the replacement unit. I would instead go with a product from a local pool supply store or service dealer.
